Honda S2000 Honda S2000
Car won't start, only 1 single click on button push
Old Jul 24, 2006 | 06:22 PM
Atheist's Avatar
Modified by Atheist at 6:31 PM 12/16/2007
Old Jul 24, 2006 | 06:37 PM
nick.na's Avatar
Default Re: Car won't start, only 1 single click on button push (Atheist)
bump for a buddy!
Old Jul 25, 2006 | 06:13 AM
stickercuttingcom's Avatar
Hit up http://www.s2ki.com if you can't find a solution here (if you haven't already tried). They have a much larger population of s2k owners that may be able to help you.
Old Jul 25, 2006 | 06:22 AM
Nishant's Avatar
Check your wiring/fuses
Old Jul 25, 2006 | 12:09 PM
dkim48's Avatar
what's the blue/red wire in the 3rd and 4th pics going to? Is there an alarm hooked up? need more info to help. Also you should get a helm's at a minimum to figure out the wiring schematics if it is an electrical problem you are dealing with. Good luck.
Old Jul 25, 2006 | 01:42 PM
Atheist's Avatar
Default Re: Car won't start, only 1 single click on button push (dkim48)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">what's the blue/red wire in the 3rd and 4th pics going to? Is there an alarm hooked up? need more info to help. Also you should get a helm's at a minimum to figure out the wiring schematics if it is an electrical problem you are dealing with. Good luck.</TD></TR></TABLE>
It's the same blue/red wire as in the last, its cut.
The alarm is not hooked up, though I think that I did at one point of it in my car. I am not sure if the unit is still there or not. Where is the stock unit?
Old Jul 26, 2006 | 09:40 AM
tico's Avatar
U shoul get the comple manufactures wiring diaghram. from there u can tell if u made a mistake
Old Jul 26, 2006 | 10:57 AM
Chillinlikeamofo's Avatar
Here's a question:
Are the battery cables on tight?
Battery at 12 volts?
Old Jul 26, 2006 | 02:13 PM
mykcuz's Avatar
Default Re: (Chillinlikeamofo)
there is a tech forum on honda tech about engines, i would ask in there, i havent started going through the wiring on my car yet
EnSAn
24
Aug 10, 2006 08:36 AM
dxhatch93
Audio / Security / Video
Apr 5, 2005 05:17 PM
enwycee
Dec 11, 2004 08:29 AM
FourthGenHatch
22
Nov 30, 2002 01:49 PM
FourthGenHatch
Nov 28, 2002 02:28 PM
