need help smoke out the tail pipe
Old Jul 24, 2006 | 04:58 PM
allmotorgsrekk's Avatar
Default need help smoke out the tail pipe
i did a swap on my civic put a b18b1 had a rebuilt head put on all honda gaskets and fully rebuilt block the compression is 195 or higher on all cyclinders it has type r oversized pistons but besides that all stock any ideas ? smoke use to be thick black put a new fully rebuilt head now its a lighter gray white runs good but smoke is killing me
Old Jul 24, 2006 | 08:56 PM
civicstar's Avatar
Default Re: need help smoke out the tail pipe (allmotorgsrekk)
could either be water or oil getting into the cyclinders. maybe the piston rings didnt seat right and they leak oil
Old Jul 25, 2006 | 11:32 AM
Default Re: need help smoke out the tail pipe (civicstar)
any way to check to see if the rings are bad?
Old Jul 25, 2006 | 12:31 PM
civicstar's Avatar
usually u do a leakdown test by pulling ur head and leveling the pistons at a certain point and pour a level amount of gas onto each piston and see in an hr if it leaks down through the piston. or u can do a compression check but thats not gonna determine if its only the piston rings.
Old Jul 25, 2006 | 03:33 PM
do you know if there is anything else that might be makeing the oil burn thanks
Old Jul 25, 2006 | 05:27 PM
civicstar's Avatar
it can usually be something to do with the head like the valve stem seals. does ur car overheat? if it does can be head gasket.
Old Jul 31, 2006 | 05:13 PM
Scott_Tucker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">usually u do a leakdown test by pulling ur head and leveling the pistons at a certain point and pour a level amount of gas onto each piston and see in an hr if it leaks down through the piston. or u can do a compression check but thats not gonna determine if its only the piston rings.</TD></TR></TABLE>
What the hell is that test called?
cmwright1986
Jul 13, 2010 12:20 PM
youryanyou
Apr 5, 2010 08:14 AM
som3on3_10
May 20, 2006 05:49 PM
ILLA_00LS
Jul 22, 2003 12:06 PM
mosaic
May 10, 2002 06:01 AM
