Skunk2 Camber Arms Squeeking??
Old Jul 24, 2006 | 01:39 PM
chrisbell37's Avatar
Default Skunk2 Camber Arms Squeeking??
I have just bought some new Skunk 2 pro series camber kit. I ahve installed them and had the camber and tracking professionally adjusted.
The problem is the camber arm bushings are squeeking really badly whenever the car goes over a bump.
I have had a look and it defienatly appears to be the camber arm bushings that came with the kit.
I have tried spraying some silicone and rubberlube on the bushings. This actully helped and stopped the squeeking but only lasted for about 4 miles then was back to its squeeky self
Can anyone give me some advice as to what to do to resolve this?
any help would be most appreciated
Old Jul 24, 2006 | 02:38 PM
ITR EG's Avatar
Default Re: Skunk2 Camber Arms Squeeking?? (chrisbell37)
are you talking about the front camber kit? because mine didn't come with bushings. I used the original Civic bushings and sprayed them down pretty good with WD-40 and they don't squeak for me.
Old Jul 24, 2006 | 02:45 PM
95jeremie's Avatar
i have the same kit same problem
bump for some advice
i just deal with it
Old Jul 24, 2006 | 02:55 PM
Surebang's Avatar
I have the Front and Rear Skunks2 camber kit. Sprayed it with WD-40.. worked like a charm..
Old Jul 24, 2006 | 03:28 PM
ITR EG's Avatar
Default Re: Skunk2 Camber Arms Squeeking?? (Surebang)
Looks like WD-40 works.
Old Jul 24, 2006 | 03:33 PM
spoonracer84eg's Avatar
Default Re: Skunk2 Camber Arms Squeeking?? (ITR EG)
Mine do the same thing. Its the bushings sqeaking.
Old Jul 24, 2006 | 11:58 PM
yeh came with the bushings. i tried lubing them but squeeking only stopped for a few miles
Old Jul 24, 2006 | 11:59 PM
Will try wd 40 and see what happens
Old Jul 25, 2006 | 12:01 AM
I have just had an e-mail back from skunk2 and this is what they said:
The reason why those are sqeaking, is that the joint were pre loaded upon
installation. All the suspenstion must be put into full travel or normal range,
and then you can tighten the joints and other connections. if you tighten the
entire assembly while the car is jacked up, it will put EXTREMELY harsh loads in
the entire assembly, causing the squeaking noise that you are describing.
But how the hell can you get a wrngch and a spanner in to toghten them when the car is back on dry land?
Old Jul 28, 2006 | 09:57 AM
Carried out the instructions of skunk2 as the e-mailed me. and Its pretty much sortrd the squeeking out.
Old Jul 28, 2006 | 10:46 AM
95jeremie's Avatar
Default Re: (chrisbell37)
have you tried the WD-40 yet?
i haven't had time with work
just wondering
Old Jul 28, 2006 | 11:09 AM
turbotime's Avatar
how does that work?
How do you tighten the suspension when the car is on the ground [with wheels on]?
And do they mean just tighten the UCA where it attaches to the shock tower or where it attaches to the upper ball joint??
Old Jul 28, 2006 | 04:28 PM
dunce11r's Avatar
Default Re:
which car are we talking about? and EG? EM? EP? im about to install my skunk2 kit this weekend, and perhaps i should lube up the bushing with grease before installing? then again, i have an EM, which the center of the bushing has a metal insert which i cant imagine would squeak....
Old Jul 28, 2006 | 06:52 PM
instrument's Avatar
so what exactly did you have to do to properly install it under load? i'm about to buy a set myself.
Old Jul 30, 2006 | 02:37 PM
Surebang's Avatar
I would like to see these intrustions. Mind posting them?
Old Jul 30, 2006 | 02:40 PM
FalkenSiR's Avatar
Default Re: (Surebang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surebang &raquo;</TD></TR><TR><TD CLASS="quote">I would like to see these intrustions. Mind posting them?</TD></TR></TABLE>
Search for "reseting bushings"
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
JRTegman987
Suspension & Brakes
Oct 22, 2006 11:38 PM
KanzenR95GSR
Apr 22, 2004 01:21 PM
Anders Lundgren
Dec 28, 2003 06:42 AM
Jason C SBB
Sep 8, 2003 08:09 AM
