Which kit ADDS negative camber and CASTER?
I have a '97 HX with Konis and H&R OE Sports, and am waiting for my swaybars to arrive. Car is not slammed.
I'm now looking into a camber kit to make camber and caster adjustable. I want to increase camber to improve cornering grip. As I understand it, increasing caster will also increase negative camber with steering lock.
Is SPC the only kit that can adjust both camber and caster?
TIA
TIA
you can pick up a little bit of caster adjustment by buying the skunk2 adjustable upper control arm and swapping the arms left to right. i've seen this done a couple of times -- the only problem comes from some instances of the UCA contacting the fenderwell, but since your car isn't slammed, it shouldn't be a problem.
as i mentioned, this kit will allow for camber adjustments, but after you've swapped the arms, there's no other way to play with caster. hope this helps...
-tony
-tony
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
