D16y7.....secondary o2 sensor question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">im pretty sure dc headers come with a o2 extension u plug in to make it longer
then u just need a cat from any other honda</TD></TR></TABLE>
ic...can anyone comfirm?....and also if you buy a header and then cat back exhaust. that leaves no room for a cat....the header blots strait up to the cat back...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor »</TD></TR><TR><TD CLASS="quote">i hacked my o2 sensor wires and extended them..DO NOT hack your stock wire harness..worked fine for me..</TD></TR></TABLE>
extended them to where? how did u get a cat in there?
the y7 header has an extension pipe hooked up to it from the cat side of the stock header to the exhaust
remove that
add whatever u header u choose then add a honda cat
they both meet the exhaust at the same spot
if u still dont get it
lemme break it down 4 u
y7 header+extension pipe=y8/aftermarket sohc header+honda/aftermarket cat
remove that
Same question here. The headers I bought already came with the sensor wire extended, and I unplugged the battery and the CEL still comes on. What to do? Im using the headers with the stock exhaust piping and muffler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKEJ6 »</TD></TR><TR><TD CLASS="quote">so the y7 exhaust manifold+extention pipe is longer then that on a y8?</TD></TR></TABLE>
i thought i explained that they are the same length because the y8 header doesnt have or need an extension pipe because it has a cat
y8 header+cat=y7 header+extension pipe
sohc vtec rex
Mar 18, 2008 01:16 PM
gulftiresinc
Sep 23, 2004 04:51 AM
