bearings
Old Jul 24, 2006 | 12:45 PM
jdm1991civic's Avatar
Default bearings
does anybody no if i can put in the main bearings with out pulling the motor? any help would be nice. O its a 1990 crx si
Old Jul 24, 2006 | 02:27 PM
doublejz's Avatar
Default Re: bearings (jdm1991civic)
yea, you can loosen up all the caps (sometime you have to remove them) and slide them in, except the end one by the tranny wont go in tho. just loosen use a screw driver and push the bearing around the crank and replace it the same way. The last time i did it, i had to pull the oil pump off so i could pull down on the crank to get enough space to slide it in.
Old Jul 24, 2006 | 05:34 PM
hizroyalty's Avatar
Default Re: bearings (doublejz)
yeh u can do a bearing roll...i wouldnt recommend it, i would pull the motor and check all ur clearances first if they are out of spec ur just going to get back in the same problem....they do sell oversized bearings im some cases, so thats the way i would go...
Old Jul 24, 2006 | 09:45 PM
SkRiBLaH's Avatar
Default Re: bearings (hizroyalty)
jeeez talk about half assing it!!
Old Jul 25, 2006 | 08:10 AM
doublejz's Avatar
Default Re: bearings (SkRiBLaH)
the way i see it.. its a 90 crx im guessing close to 200k miles. do you really wanna go through all the work to replace a main bearing..
xxmastermindxx
Jun 14, 2007 03:05 PM
pinecone
15
Jun 30, 2006 11:50 AM
Riceboy891
Aug 4, 2005 05:11 AM
jdmcivicferio
Mar 16, 2003 06:54 AM
filetofit
Oct 23, 2002 05:10 PM
