MINI ME BUILD, WHAT PISTONS? NEED HELP?
Old Jul 24, 2006 | 11:01 AM
projectef's Avatar
Default MINI ME BUILD, WHAT PISTONS? NEED HELP?
IF I DID A MINI ME, WOULD I HAVE TO USE THE PISTONS FOR THE A6 BLOCK, OR USE THE PISTONS FOR THE Z6 HEAD?
Old Jul 24, 2006 | 11:25 AM
crxnj's Avatar
Default Re: MINI ME BUILD, WHAT PISTONS? NEED HELP? (projectef)
You can use either pistons,,just depends what compression you're looking for..The pm6 d16a6 pistons will give higher compression ratio then the p28 d16z6 pistons..
http://www.knology.net/~jediklc/dcalc.htm
Old Jul 24, 2006 | 11:30 AM
dr_latino999's Avatar
Default Re: MINI ME BUILD, WHAT PISTONS? NEED HELP? (Mr.speaker)
If you use the A6 pistons, which has been done a zillion times in the past, remember that the valve reliefs are different in the pistons compared to the Z6 pistons.
Old Jul 24, 2006 | 11:31 AM
projectef's Avatar
SO IF I USE THE A6 BLOCK WITH THE PM6 PISTONS, IT WILL BE OK, IT WONT DAMAGE THE VALVES ON THE Z6 HEAD.
Old Jul 24, 2006 | 11:36 AM
projectef's Avatar
WHAT DO U MEAN? SO ITS OK TO USE THE PM6 PISTONS
Old Jul 24, 2006 | 12:25 PM
d16vtecx's Avatar
yes its perfectly ok
there are plenty of people with this set up
the tricky thing is when you use pm7/p29 pistons
Old Jul 24, 2006 | 12:42 PM
projectef's Avatar
Default Re: MINI ME BUILD, WHAT PISTONS? NEED HELP? (d16vtecx)
between a 10-5-1 comp... and a 11-0-1 comp... is it a really big differnece
Old Jul 24, 2006 | 12:45 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">between a 10-5-1 comp... and a 11-0-1 comp... is it a really big differnece</TD></TR></TABLE>
not noticable, no. but it might be noticed as detonation depending on the condition of your motor...so use decent gas.
Old Jul 24, 2006 | 12:50 PM
projectef's Avatar
Default Re: MINI ME BUILD, WHAT PISTONS? NEED HELP? (SIred91)
I ALREADY HAVE A BUILT Z6 HEAD, WHAT DO U THINK IS A BETTER BUILD? MINI ME OR STARIGHT Z6
Old Jul 24, 2006 | 03:44 PM
user 98292739's Avatar
whats with all the caps? your screaming in my head...please stop...
a better build hmmm could be argued since the a6 has a better girdle, but IMO i would if i could go straight z6.
tasco
May 21, 2015 09:41 PM
Wheelman-CZ
Jan 7, 2008 12:52 AM
hondaboyB18C1
Dec 23, 2003 09:30 PM
daniboy4nspd
May 23, 2003 10:53 AM
