95 accord won't start
tried to start , after releasing the key it stalled and has'nt staretd since.
fuel pressure is good,engine turns over, spark seems to be good.
new plugs and wires. HELP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edsymister »</TD></TR><TR><TD CLASS="quote">, after releasing the key it stalled and has'nt staretd since.
what you mean after turning the key to start, then letting it reast in the on postion? when did this problem start happening? you could try looking at your timing belt the teath might be striped.
give some more info on when the problem started
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edsymister »</TD></TR><TR><TD CLASS="quote">spark seems to be good</TD></TR></TABLE>
Does that mean you have spark or you assume you have spark because you replaced the plugs and wires?
Make sure you have spark. Pull one of the plug wire and hold it to a ground or if you have a spark plug, put that in the end of the plug wire. Have someone turn the key to the start position while you watch for a blue spark to jump between the plug wire and ground or in the spark plug if thats what your using.
Very rare but have seen this twice in the shop.... the ignition switch could be bad... i had this same problem and chased it literally for 2 hours before coming to the conclusion the switch was bad. like i said thought very rare... check for sure there is spark and fuel then i would pull the timing cover and take a peek.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edsymister »</TD></TR><TR><TD CLASS="quote">tried to start , after releasing the key it stalled and has'nt staretd since.
new plugs and wires. HELP</TD></TR></TABLE>
Have you been able to start it again? Here's a test for the ignition switch. Hold onto the key so that the engine begins to start, instead of completely letting go of the key, just turn it back slightly (allowing the starter motor to disconnect). If the engine keeps running, then the ignition switch is bad. Also, if the engine dies when you let go of the key, look at your instrument panel, if all the guages and lights are OFF, then it is a bad ignition switch.
drove the night before,seems ok.
in the AM turned the key (pos lll), it started, released the key it stalled (pos ll)
I may have to check the timing or distributor (head was replaced last year because of broken timing belt)
yep if the switch is not makeing contact, being corosien, carbon build up, or is bent out of postion then it will not close the circirut to start the car. now do the lights come on? does it beep at you? or is it just completly dead? no light no beeping nothing? if so check your battery, termainals, wires, both at the battery and the ignition system.
dash Lights R on ,key in ignition beep & door open beep,engine turns over but does not start.
Modified by edsymister at 6:36 AM 7/26/2006
so then try try useing a test light to make sure the starter is getting power, if not trace it back to the switch, by the way is the starter siloniod (i know, I cant spell) engaging? Or does the starter just spin without jameing the ring gear into the flywheel? if neither, check the clutch safty switch if manual.
