2000ex with b16a Hard to start only after Re-Fuel
Old Jul 24, 2006 | 05:41 AM
B16CivicEX's Avatar
Default 2000ex with b16a Hard to start only after Re-Fuel
hey guys i have a 2000EX WITH a b16a swap, the starts and runs great, but after i put fuel into it, it will crank for a few min and wont start.. after about 2 min it alowys starts, i can refuel with 1/2 tank 1/4 tank or empty, same thing.. i even did a test and filled it up and 50 miles later put anohter gallon in, and same thing, crank crank crank.. hard to start.. once its started, it will start first shot all the way till empty.. i can have it on E and it will start first shot. Just when refuel it wont start for few min, any ides?
Old Jul 24, 2006 | 07:17 AM
GiMpInThaCiv's Avatar
It has a mind of its own?
Old Jul 24, 2006 | 07:44 AM
B16CivicEX's Avatar
tell me about it
Old Jul 24, 2006 | 08:01 AM
Morning Call's Avatar
maybe your losing pressure from when u open the cap
try removing the cap and putting it back on then starting it. im guessing that itll give you the same problem.
Old Jul 24, 2006 | 08:17 AM
miahmouse's Avatar
Default Re: 2000ex with b16a Hard to start only after Re-Fuel (B16CivicEX)
Same thing with mine. I've heard all different explanations, people putting the SI pump in, turning the ignition on and letting the car sit for a few... mine only does it every once in a while and most often when the car is cold... go figure...
Old Jul 25, 2006 | 04:16 PM
B16CivicEX's Avatar
up
Old Jul 30, 2006 | 05:40 PM
B16CivicEX's Avatar
bump
Old Jul 30, 2006 | 05:49 PM
cambopheonix56's Avatar
Default Re: (B16CivicEX)
Mine does the same thing.
Old Aug 1, 2006 | 04:53 PM
B16CivicEX's Avatar
Default Re: (cambopheonix56)
bigJOE671
Sep 17, 2012 04:55 PM
mynameizstitch
Mar 17, 2012 10:55 AM
z06eateR
28
Mar 23, 2009 09:38 AM
crxcess
Jun 10, 2006 06:05 AM
