b18b
just got to swapin a b18b in my 94 civic coupe...\
but it wont start, alll i can hear is a click coming from the starter.....
i already check for gtounds, charge battery, for fuses,,,, except for a starter relay if there is one,,,, but i cant find it, is the starter relay same as the main relay??
really need help..... thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon »</TD></TR><TR><TD CLASS="quote">any other ideas</TD></TR></TABLE>
If your starter relay was messed up your electronics would activate when switching to II and then once hitting III on iginition everything would turn off and the engine wouldn't even click. I'd check the dizzy
Horna - Envaatnags Eflos Solf Esgantaavne (2005) - - Marraskuussa - In November.mp3 [224Kbps] (08:43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon »</TD></TR><TR><TD CLASS="quote">i'll already did... i used my brothers... same prblem.... but thanx/////
any other ideas
Well, check your battery again...or just swap in someone else' battery
Burzum - Hvis Lyset Tar Oss (1994) - 1/4 - Det som en gang var.mp3 [128Kbps] (14:21)
any other ideas
</TD></TR></TABLE>Well, check your battery again...or just swap in someone else' battery
Hmm. Could be a main fuse, though you said you checked fuses. I remember when my Ford Probe did this, it was because the postitive battery wire was too old and weak, I replaced the head of the positive battery connector and it ran perfect. Could be the same for the negative terminal as well. And I as well thought it was the main relay, though your relay could be fried. Take off the old relay, and relay it yourself with some thick grade wire
[X] You've checked the dizzy
[X] Fuses
[X] Battery
[ ] Starter
[ ] Alternator
[ ] Plugs
[ ] Wires
Hmm, let me ponder awhile.....your question is giving me nightmares
Burzum - Hvis Lyset Tar Oss (1994) - 2/4 - Hvis lyset tar oss.mp3 [128Kbps] (08:04)
[X] Fuses
[X] Battery
[ ] Starter
[ ] Alternator
[ ] Plugs
[ ] Wires
Well if your alarm isn't wired properly it will seize you from starting your car, or if you took the alarm out and never patched the old wiring back up, you'll have this problem
Winger - Winger (1988) - 02 - Hungry.mp3 [64Kbps] (03:58)
yes it starter before i did the swap... all the grounds are hook up.....
starter cames out but it wont spin....
auto zone says that is mess up
oreilley say that is good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metalluthier »</TD></TR><TR><TD CLASS="quote">
DIdn't know that...learn somethign new every day
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon »</TD></TR><TR><TD CLASS="quote">yes it starter before i did the swap... all the grounds are hook up.....
oreilley say that is good</TD></TR></TABLE>
So what's stopping u from knowing the starter isn't jammed/broken?
cksnah252
12
Sep 9, 2014 07:51 AM
Schultzie
Jan 23, 2013 09:46 PM
Junkyard2000
Jul 4, 2005 10:55 PM
