How to adjust IDLE on 00 GSR?
Old Jul 23, 2006 | 07:24 PM
GsrVtec's Avatar
Default How to adjust IDLE on 00 GSR?
Hello I was wondering as to how to adjust the idle on a 00 GSR. Ive tried using the idle control adjustment the one that you use with a flathead rite on the throttle body. But the idle didnt move one bit. I even took the whole idle adjustment screw out and the idle didnt rise or nothing. Reason I want to adjust my idle is because rite now its diling at around 650-700rpm and at about almost 600 with the AC on. Is there any ither way to adjust my idle?
Very important: Y isnt my Idle adjustment screw working (the one that is used with a flat head and rite above the throttle body)? loosen and tighten it and the RPM stays the same?
Old Jul 23, 2006 | 09:20 PM
Thepanda's Avatar
Default Re: How to adjust IDLE on 00 GSR? (GsrVtec)
What you are supose to do is let the car warm up before you adjust the screw then unplug the sensor on the IACV then adjust your idle to 400 I belive. you then turn your car off pluf the sensor in and it should work. here is a good article on idle related issues. http://www.superhonda.com/foru...59965
Old Jul 24, 2006 | 10:51 PM
teamsoy1320's Avatar
Default Re: How to adjust IDLE on 00 GSR? (Thepanda)
good looking out thank you alot
turboman
Jun 10, 2005 10:31 AM
1hotcivicSi
Apr 24, 2004 09:11 PM
killa_lude
Aug 16, 2003 08:33 AM
Marcos
Apr 13, 2003 05:00 PM
