just did a compression and leakdown
i thought that putting oil in the cyl. then doing a compression test was a leakdown...
so i guess the numbers that i posted are befor and after putting oil in the cyl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">i thought that putting oil in the cyl. then doing a compression test was a leakdown...
so i guess the numbers that i posted are befor and after putting oil in the cyl.</TD></TR></TABLE>
nope, leak down is when you pressurize the cylinders. Sounds like you have ring problem with the numbers coming up that much with oil in cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 »</TD></TR><TR><TD CLASS="quote">lol, so if that is after the oil drop, then yes rings.</TD></TR></TABLE>
not always, don't do **** without a leakdown test.
compression tests are pretty much worthless... they will only show one of two things:
A) The cylinder is bad for sure.
B) The cylinder could be bad maybe.
so do a leakdown test!
Fat Chick Magnet
Nov 22, 2006 09:52 PM
