Question for those of you running Eagle Rods your H22A
Old Apr 22, 2002 | 12:49 PM
Smurfylude's Avatar
Default Question for those of you running Eagle Rods your H22A
What are your typical rod bearing sizes that you have used???
Old Apr 22, 2002 | 01:31 PM
Greyout's Avatar
Default Re: Question for those of you running Eagle Rods your H22A (Sushi X)
not to sound like a noob but could someone please explain the 'different size' of bearings to me? how do you know, how are they sized, and WHY?
Old Apr 22, 2002 | 02:19 PM
Smurfylude's Avatar
Default Re: Question for those of you running Eagle Rods your H22A (JDM LUDE)
the bearing are color coded and the different color's tell you what size they are
Old Apr 22, 2002 | 09:39 PM
Xav H22EG8's Avatar
all vary.. if I tell you all my sizes it wouldn't matter..
Old Apr 23, 2002 | 09:31 AM
Smurfylude's Avatar
Default Re: Question for those of you running Eagle Rods your H22A (Xav H22EG8)
Just wondering what colors did you use thought???
Old Apr 23, 2002 | 04:45 PM
schwett's Avatar
New User
you know what's wierd - ALL The bearings in my 2000 sh (h22a4) were exactly the same as far as i could tell from markings. none were "colored," and the block was stamped "4 4 4 4 4." i looked hard, not a bit of color anywhere. they were all plain old metal.
now that could be very bad luck (isn't 4 bad luck in feng shui?) or very good. anyone else taken apart a 2000+ block?
Old Apr 23, 2002 | 07:39 PM
h0mesk1let's Avatar
Default Re: Question for those of you running Eagle Rods your H22A (schwett)
typically with eagle rods i have seen nothing but green bearings. the difference between the largest and smallest honda-acura bearing is the average difference in a domestic bearing. I dont think you could go wrong.
Old Apr 23, 2002 | 07:47 PM
schwett's Avatar
New User
Default Re: Question for those of you running Eagle Rods your H22A (EGb18cT)
what part of the bearing is colored!?!?!
the sides, i assume? is it a teensy dot or something? or is there one type that's not colored, and i just by chance got only those?
Old Apr 23, 2002 | 07:55 PM
h0mesk1let's Avatar
you match the numbers on your crank with another number which is from the rods. then you go to your honda manual and match the two numbers together and they give you a color, then you know what to ask for at the dealer.
JDM_ego2033
Engine Machining & Assembly
May 7, 2018 09:43 PM
BubbleSnail
Dec 20, 2009 01:34 PM
blkb18
Feb 5, 2008 08:07 PM
Smurfylude
Apr 22, 2002 02:39 PM
