HELP!!! Are these compression readings correct?
Old Jul 23, 2006 | 12:44 PM
Brandon31386's Avatar
Default HELP!!! Are these compression readings correct?
I did a compression test on my B16A2 today. The readings go as followed:
#1: 180psi
#2: 180psi
#3: 180psi
#4: 180psi
I was told that if you have bad compression, the rings are most likely bad. Also my B16 burns oil(I posted a while ago about it). If someone could tell me if these readings are correct or not, that would be greatly appreciated. Thanks!
Old Jul 23, 2006 | 12:56 PM
Default Re: HELP!!! Are these compression readings correct? (aallbbeerrtttttt)
thank you! So the oil burning problem must be my valve guide seals then right?
Old Jul 23, 2006 | 02:11 PM
kaiba's Avatar
Default Re: HELP!!! Are these compression readings correct? (Brandon31386)
I though b16 was 200-210 across.
Old Jul 23, 2006 | 05:00 PM
gotboostedvr6's Avatar
Default Re: HELP!!! Are these compression readings correct? (kaiba)
mine is 230 + across
Old Jul 23, 2006 | 10:56 PM
so what should the reading be then???
MBlake55
Jul 27, 2009 04:56 PM
b16a95eg
Oct 25, 2007 11:36 AM
tommy.
Mar 28, 2006 12:31 PM
davidcrx89
Jun 26, 2005 10:52 PM
mustbenu
Jan 23, 2004 12:56 PM
