NEED HELP TAKING OUT FRONT STUDS ON A 96 GSR
THE THINGS TO BOLT THE LUG NUTS TO ONE IS STRIPPED AND I NEED TO REPLACE IT....BUT I CAN TAKE IT OUT IVE GOT THE DISKS OUT NOW ITS JUST THE HUB AND THE STUDS BUT I HAVE NO ROOM TO PUSH THE STUD BACK TO TAKE IT OUT?
On my rears I just banged them out and and they came out but it would depend on how short they have broken off to. After that i got them in as far as I could then put my wheel back on lowered the car down and tightened the nut until it pulled the stud through.
For my fronts I replaced them with ARP extended studs so I had to take the hub off, bang the old ones out and bang the ARP's in. I used a slide hammer to get the hub off, and it sucked.
You may have to take the hub off to replace them.
get one of those plier clamper thingys. I forgot what they are calling, but these pliers tighten very very hard, and you can take your stud out, if someone knows what it is called, please say
ok so i got the axle out but now ....its still stuck on the bottom screw but i should figure that one out i just gotta hammer it up i guess...damn i should of bough extended studs already now would have been the time to put them in cuz im not doing this **** again loll...but ya thanks for the help guys
ya about that screw its not as easy as i though so im really thinking of puting all this back together and just making new tread on the dam stud
well if anyone cares lol ummm ended up just fixing the stud ...so i put everything back and just smoothed out the messed up parts which was like 2 rows of tread and now its all kool finally ....thanks
Lei Siew Long
Mar 4, 2002 12:05 AM
