Needle Recalibration...
Speedo needle?
With the car on and the needle removed, but not moving (the car), stick the needle back on the pin but slightly below the stop pin. Then slide the needle over the stop pin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Speedo needle?
With the car on and the needle removed, but not moving (the car), stick the needle back on the pin but slightly below the stop pin. Then slide the needle over the stop pin.</TD></TR></TABLE>
Blah...put it below the pin...then move it above the pin? Why not just put it down over the pin?
(Yeah I've never put needles back on before....so I'm j/w...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
(Yeah I've never put needles back on before....so I'm j/w...)</TD></TR></TABLE>
Because when you push down on the needle, you also push the needle up if not careful. When you are at rest, the needle may not rest at 0.
Modified by BlueIntegraBoy at 5:27 PM 7/31/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Don't take this the wrong way..
But is english ur first langauge?</TD></TR></TABLE>
Yes, read it again.
When you push down on the needle, you will push the needle up the dial if you are not careful. When you are at rest, the needle will not come back to 0 MPH.
Sorry, when I type fast, I tend to type in other words.
Yes, read it again.
Yes, read it again.
Sorry, when I type fast, I tend to type in other words.</TD></TR></TABLE>
Oh, I got what ur saying now, it makes sense now, I just woulda worded it like "push it down, but becareful not to push it up the dial or it won't be accurate"
I got ya
so how would u do the tach? just turn the key to the on position but don't start the car?
Yes, read it again.
I got ya
I got ya
so how would u do the tach? just turn the key to the on position but don't start the car?</TD></TR></TABLE>
Umm, if you know where your car idles at normally, I would stick the needle pointing to that position after your car has warmed up. I never had to recalibrate the tach, but it shouldn't be too much different than the speedo.
I got ya
Umm, if you know where your car idles at normally, I would stick the needle pointing to that position after your car has warmed up. I never had to recalibrate the tach, but it shouldn't be too much different than the speedo.</TD></TR></TABLE>
Yeah that's what I was thinking, but it's more estimated since u can't put it in at 0
what happens if you do it while the car is off?
silvercivichatch
Jul 31, 2004 10:39 PM
CivicSwapper
13
Dec 24, 2003 10:48 AM
