B18C Smoking
Old Jul 22, 2006 | 07:13 PM
DelSolMarine's Avatar
Default B18C Smoking
so im getting EXTREME smoke when i get into VTEC its like the people behind me are in a cloud... is that normal cause i know its burning a little oil but nothing extreme i check it like every other day..
Old Jul 22, 2006 | 07:18 PM
Hmoob_Lee_guy's Avatar
Default Re: B18C Smoking (DelSolMarine)
What color smoke are you blowing?
Old Jul 22, 2006 | 07:20 PM
Default Re: B18C Smoking (Hmoob_Lee_guy)
looked white when i looked threw my rear view like normal smoke cept hardcore lol
Old Jul 22, 2006 | 07:30 PM
JDM B16A's Avatar
Your headgasket is fucked up. Coolant is is going into your combustion chamber and you're mixing it with fuel and air. That what cause the white smoke. Get new heaD gasket and run your car for like 100 miles and it'll clear up.
Old Jul 22, 2006 | 07:46 PM
Default Re: B18C Smoking (JDM B16A)
how much is labor for a headgasket...
Old Jul 22, 2006 | 07:48 PM
JDM B16A's Avatar
I'm a hardcore noob when it comes to honda-motor but even I can replace a headgasket. Do a Search maybe you can find step by step instruction.
Old Jul 22, 2006 | 08:13 PM
Syndacate's Avatar
u usually get charged up the *** for labor on a headgasket, do it yourself.. I would really recommend buying the Acura GSR (whatever year ur engine is) head gasket directly from Honda/Acura and installing it yourself... Search for some how-tos on changing the headgasket, it's really not difficult...and if you have any questions I'm sure pple here can help you...I'm always open to PM's if you got a question..
Though if u wanna take it to a shop it's ur call...I'd suspect around 200-300 for labor as most garages would charge about 4 - 6 hours labor at 65 (approx) / hour that goes to about 260 - 390....but u may be able to find it cheaper....
Like I said, better to do it yourself, really is...
Old Jul 22, 2006 | 08:15 PM
Default Re: (Syndacate)
well i have a friend he helped me put my motor in so... but 4-6 hours was what i was wanting to know... but what about the mugen headgasket... i figure i spent over 3500 on a motor swap might as well get good parts... the mugen headgasket says it raises compression from 11.1 to 11.4? worth the money?
Old Jul 24, 2006 | 04:33 PM
Default Re: (DelSolMarine)
anyone have a response on the mugen headgasket?
Old Jul 24, 2006 | 06:15 PM
bump...
Old Jul 24, 2006 | 06:21 PM
MurdersV8s's Avatar
mine is doing the same. is there a difference between jdm and usdm head gaskets?
Old Jul 24, 2006 | 06:28 PM
Default Re: B18C Smoking (MurdersV8s)
good question.. been trying to get some help on this for a while... i dont know what 2 do... is it possible that because all my exhaust is redone that i could just be running really rich so its making smoke?
Old Jul 24, 2006 | 06:50 PM
vlc92189's Avatar
bro.. my gsr did the same exact thing when i was in vtec.. but i changed my oila nd filter.. went from regular oil to syntec blend and it dont smoke.. at leas not noticible.
Old Jul 24, 2006 | 06:51 PM
Default Re: (vlc92189)
i run castrol synthetic all the time.. so yea thats def not it
trojan
Feb 26, 2012 02:18 PM
jeresaur
Mar 13, 2011 05:00 AM
caliEG2dr
May 15, 2010 12:44 AM
the_dxB16
Dec 25, 2008 01:23 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
