Cheap brake setup for 99 si?
Old Jul 22, 2006 | 05:12 PM
kinkyintegra's Avatar
Default Cheap brake setup for 99 si?
I need to get my front brakes changed so i can pass my inspection. So what can be a cheap front brake setup for a 99 si. The front right brakes are squeaking so i figure might as well replace both up front. What kind of setup can i get thats including rotors and pads for a cheap price? Pretty much a temp until i save up for brembo blanks and good pads.
Old Jul 22, 2006 | 06:25 PM
BlueIntegraBoy's Avatar
Default Re: Cheap brake setup for 99 si? (kinkyintegra)
Why don't you get the Brembo blanks and pads now? They will cost you maybe around $120. If you plan to spend money on like autozone rotors, they will cost anywhere from $20-40 each and pads for another $20-30. I say do it right the first time so you don't have to go back and change everything.
Old Jul 22, 2006 | 06:57 PM
cambopheonix56's Avatar
Default Re: Cheap brake setup for 99 si? (BlueIntegraBoy)
Might as well listen to ^^^
Old Jul 22, 2006 | 06:58 PM
yeah but i dont have money like that i have like 50 60 tops and then i have to do an inspection.....
Old Jul 22, 2006 | 07:05 PM
Default Re: (kinkyintegra)
Cant pass inspection with squeaky brakes? At least they work, right?
Old Jul 22, 2006 | 07:06 PM
Yeah they work just rub when they get hot...
Old Jul 22, 2006 | 07:10 PM
As long as you pass...
KLackeyImages
12
Jan 26, 2022 07:54 AM
mysterysktr7
Jun 5, 2009 02:11 PM
xyooj
Sep 14, 2006 08:07 AM
6ghatch
32
Jul 17, 2004 04:33 PM
batibot
26
Apr 2, 2003 02:40 PM
