Skunk2 stage 2 cams on a turboi set up
Old Jul 22, 2006 | 02:48 PM
ghettochild's Avatar
Default Skunk2 stage 2 cams on a turboi set up
i was just wondering if anybod has used a set on there turbo set up and if it was worth a ****. cause ive talked to some people and they would be good for turbo
just wanting some more info on them
Old Jul 22, 2006 | 05:47 PM
Mugencrxsir1's Avatar
Default Re: Skunk2 stage 2 cams on a turboi set up (ghettochild)
They run really well, but it's kinda high lift for street use, nice to have if you are dragging only. Plus reliablity will go down with the more aggressive you make your set-up, but yes these cam specs make a lot of power with the right tuner.
Old Jul 22, 2006 | 05:49 PM
Default Re: Skunk2 stage 2 cams on a turboi set up (Mugencrxsir1)
Over lap will be an issue with high lift NA cams, but proper tuning should make these cams sing! Alot of HT users are running NA cams with 20-30hp gains at the top.
92Snatch
Mar 25, 2013 01:29 PM
crashsvg
May 19, 2010 06:44 AM
Egpower88
Feb 14, 2009 07:32 PM
InvaderTrax
Dec 13, 2005 09:49 AM
RTW DC2R
Jun 4, 2004 11:48 AM
