Took My R to Acura this mourning for what I thought would be tranny problems..
Old Apr 22, 2002 | 10:16 AM
TeamRedlineITR's Avatar
Default Took My R to Acura this mourning for what I thought would be tranny problems..
I tell them i think my 3rd gear synchro might be shot, (bcuz of all the info I have gathered up from H-T and other sources, on the symptoms that my car has) the grinding from 2nd into 3rd gear... and thats only time that it is doing this no other gear is grinding...
Anyway... A Tech takes it for ride to hear the grinding, comes back tells service rep guy that its Possibly the clutch/ spring on the clutch or some kind of **** like that....
I have never seen or heard of someone having this kind of problem like this before??? Can a clutch spring (or whatever with a clutch) cause a grinding problem in ONLY one gear???
Service rep guy tells me they will order new clutch or whatever the **** and come back next Monday for them to start fixing it.
Can someone tell me if this even sounds like this is the problem with my car?? If it is the clutch could I get them to install a clutch that i want???
Any info would be great guys thanks...
Old Apr 22, 2002 | 10:30 AM
onyx00's Avatar
Default Re: Took My R to Acura this mourning for what I thought would be tranny problems.. (TeamRedlineITR)
I don't think a clutch spring would causes grinding in only one gear.
But look at it this way, it's warrenty, so you get a new clutch free! If that doesn't fix the problem, they still have to do work on it under warrenty. So worst case you get a free new clutch and a new 3rd gear synchro.
Old Apr 22, 2002 | 10:32 AM
Floyd's Avatar
Honda released a Technical Service Bulletin about the clutch spring possibly breaking and coming loose. Since then, I think the dealers have been trigger ahppy in using this as a standard diagnosis. I don't know the specifics of your problem, but it could be something different. i would let them rplace the clutch (for free) then when the problem persisits they will have to go into the tranny to check it out. I'm not sure what kind of luck you would have trying to convince them of anything else. Let them find out the hard way.
As far as having the dealer install an amtermarket clutch for you... highly unlikely.
Old Apr 22, 2002 | 10:35 AM
Default Re: Took My R to Acura this mourning for what I thought would be tranny problems.. (onyx00)
Hehehe very true,
I just dont like downtime on my R bah
Old Apr 22, 2002 | 10:45 AM
Default Re: Took My R to Acura this mourning for what I thought would be tranny problems.. (Floyd)
AHA! so thats why the techy was so quick to say that it might be a clutch spring,
hhhmmm i only have about 16k miles on my car.
Im gonna try to get that old clutch off thier hands, If they actually replace my clutch and if its not the problem, I know I will have a extra clutch that i can use whohoo, NEVER had any kind of problems with my clutch, i know its in great shape if its not the problem...
Thanks alot Floyd
[Modified by TeamRedlineITR, 2:46 PM 4/22/2002]
Old Apr 22, 2002 | 11:18 AM
onyx00's Avatar
They are probably not going to give you the old clutch.
Old Apr 22, 2002 | 11:21 AM
Tommy_Gunns's Avatar
Yeah, I had my ECU replaced and they would not give me the old ECU...dang it!!!
Old Apr 22, 2002 | 02:55 PM
Nighthawk GS-R's Avatar
New User
Default Re: Took My R to Acura this mourning for what I thought would be tranny problems.. (Tommy_Gunns)
well yeah u can get ur clutch replaced. im not sure what the down time is on that 2 days maybe?? but i know for a fact its ur synchros. the same thing happened to my 01 gsr. the only problem was the part was on backorder for 7 days so i was without my car for 12 days. Good thing for loaners......anyway the point is ull get your car back and then youll have to waite again.. for some reason alot of 01 tegs have synchro problems, especially third. i just got mine back and i can tell u it feels better than the day i bought it.......
Old Apr 22, 2002 | 07:26 PM
I could see why they wouldnt want to give up the old ECU, those could be fixed pretty easy I would think... But not letting me have a *possibly* fucked up clutch? why, what could they do with it? wouldnt they want to just trash it??
Old Apr 22, 2002 | 07:35 PM
xjohnx's Avatar
from what i understand, they send malfuntioning parts like that back to honda for R&D, that way honda can figure out why it broke, and make it so they don't break in future models.
Old Apr 22, 2002 | 07:40 PM
Default Re: Took My R to Acura this mourning for what I thought would be tranny problems.. (xjohnx)
Bah, yeah I forgot all about that, Makes sense...damn sure would be nice to have an extra working clutch around though
Old Apr 22, 2002 | 09:52 PM
b19coupe's Avatar
When parts are replaced under warranty, Honda has the option of calling for them within thirty days.The dealer will not give you parts replaced under warranty, they can't. If they don't have a part when Honda calls for it, Honda debits their account for the amount of the part + the labor. And it sounds like your problem is a synchro problem. The clutch spring problem usually appears in all gears and makes it a bitch to get into first and reverse.
Old Apr 23, 2002 | 12:31 AM
Default Re: Took My R to Acura this mourning for what I thought would be tranny problems.. (b19coupe)
Right on, exactly what I thought, but u know u cant tell a service rep a damn thing without them thinking u dont no **** about what ur talking about. (unless they know u)
O well, like it was said before in this thread "let them find out the hard way".
wickedEFguy
Mar 27, 2005 12:20 PM
pinoyboy204
Apr 28, 2004 03:59 PM
RJL
Nov 28, 2003 11:25 AM
tegmaniac
Jul 23, 2003 08:13 PM
eg_hybrid
Oct 6, 2001 08:27 AM
