vtec
Old Jul 22, 2006 | 03:01 AM
hondatuningboi96's Avatar
Default vtec
as the title says, i have done the h22 swap now i'm having codes now 7, 9, 14, 22, and also 41. 22 is the vtec pressure valve is that or could be the vtec silonoid<===spelling yeah i know! but anyway these plugs are just about the same and i don't know if i have them in the right place i know the vtec is plugged in right i think it has one wire running to it green/yellow. If u could help me please! Also the code #9 the cyp crank sensor wtf?????
Old Jul 22, 2006 | 07:03 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: vtec (hondatuningboi96)
you shudda searched first...here are the codes.....
http://hybrid2.honda-perf.org/tech/codes.html
Old Jul 23, 2006 | 05:58 AM
Default Re: vtec (I got the CD5 Jeebies!)
ok i know the codes but still having the same issues
Old Jul 24, 2006 | 05:54 PM
BlUAc's Avatar
do you have a ex accord I have noticed that sometimes it will shoot like 2 or 3 codes for one problem or it will give a code for something else that is working like an ecu will shoot a lean o2 sensor code for a plugged fuel injector if you have an ex you gotta swap pins a6 and a11 cuz the POA ecu has the o2 and egr swapped hope that helps
Old Jul 27, 2006 | 07:59 AM
Default Re: vtec (BlUAc)
why should i do that if i have a jumper harness obd2 to obd1
vtec25
May 11, 2011 09:13 AM
daredeezy619
12
Mar 6, 2008 05:41 AM
SoHc94
Apr 28, 2007 12:21 AM
UNDER PRESSURE
Jan 8, 2005 05:05 PM
fsck3r
Aug 17, 2003 11:46 PM
