Action 2KS clutch owners!(or anyone) Do you have this problem?
Old Jul 21, 2006 | 11:03 PM
mRek9R's Avatar
Default Action 2KS clutch owners!(or anyone) Do you have this problem?
UPDATED
08/27/2006
-Well..opened up my tranny this past weekend and whoopee! my flywheel, pressure plate and disc seem to be all warped! Also, the squeaking was from the t/o bearing rubbing on the shaft; the lube had dried up like a desert. I had to literally use a rubber mallet to force the t/o bearing out. Here are the pictures:
FRESHLY RESURFACED!
I now have an Action 2MD and that sucka bites fast and hard!!!!
OLD POST BELOW
It seems like my Action 2KS clutch does NOT like heat or repeated "beatings." At the track, the first two runs will are great! But after the third and beyond, the clutch just won't grab, and if it does it seems like it's slipping. Happens all the time when I drag or auto-x.
The kit has roughly 10k on it, master and slave are almost brand-new. There have been a couple of times where my pedal has stuck to the floor. I'm planning to replace the slave one of these days or rebleed the whole system(I'm running Motul DOT 5.1 in the clutch, shouldn't affect it? Right?).
I do have some squeaking when i depress my clutch pedal, the sqeak coming from inside the tranny(my guess is the fork/pivot is no longer lubed and needs lube).
Any of you guys have this problem or similar problems? Any suggestions? Thanks, 8)
Modified by mRek9R at 9:19 PM 8/31/2006
Modified by mRek9R at 9:22 PM 8/31/2006
Old Jul 22, 2006 | 08:59 AM
igo4bmx's Avatar
i had the exact same problem with my spec stage 2 clutch, (which also has a kevlar face)
I believe the kevlar cannot handle the heat of constant abuse.
since then i switched to a comp clutch stage 4, and it rides just as smooth but holds the power, and does not slip
Old Jul 22, 2006 | 03:14 PM
platinum00's Avatar
Default Re: Action 2KS clutch owners!(or anyone) Do you have this problem? (mRek9R)
I run the 2MS and dont have that issue.
are you sure you did not get oil on it during installation?
how much power are you making
platinum.
Old Jul 22, 2006 | 09:23 PM
igo4bmx's Avatar
Default Re: Action 2KS clutch owners!(or anyone) Do you have this problem? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">I run the 2MS and dont have that issue.
platinum.</TD></TR></TABLE>
thats not a kevlar face
Old Jul 22, 2006 | 10:44 PM
mRek9R's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">i had the exact same problem with my spec stage 2 clutch, (which also has a kevlar face)
since then i switched to a comp clutch stage 4, and it rides just as smooth but holds the power, and does not slip </TD></TR></TABLE>
Thanks for the reply; I too think that the kevlar cannot withstand the constant heat created from repeated abuses. Maybe it's time to re-do with another kit. That Comp stg.4 looks pretty interesting, i might have to try that out too. 8)
I'm positive on the no oil issue, i'm currently rated at 274whp and 204tq and i'm looking to make even more power with a new intake manifold and forged internals. 8)
Old Jul 23, 2006 | 08:34 AM
igo4bmx's Avatar
Default Re: (mRek9R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRek9R &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply; I too think that the kevlar cannot withstand the constant heat created from repeated abuses. Maybe it's time to re-do with another kit. That Comp stg.4 looks pretty interesting, i might have to try that out too. 8)
I'm positive on the no oil issue, i'm currently rated at 274whp and 204tq and i'm looking to make even more power with a new intake manifold and forged internals. 8)</TD></TR></TABLE>
from what i recall with other kevlar disc owners, they all had the same issue.
do a search, cuz i remember someone mentioning the same issue we both had and with the action 2ks.
th disc will last forever, but does not hold up to heat
Old Jul 23, 2006 | 09:44 AM
ghostskinner's Avatar
what causes theclutch pedal to sink is it the clutch slave cylinder or the pressure plate
Old Jul 23, 2006 | 10:58 AM
quicksilver1689's Avatar
i ♥ snails
i have a noob question, what kind of fluid is used in the clutch master cylinder?
Old Jul 23, 2006 | 11:46 AM
mRek9R's Avatar
Default Re: (ghostskinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostskinner &raquo;</TD></TR><TR><TD CLASS="quote">what causes theclutch pedal to sink is it the clutch slave cylinder or the pressure plate</TD></TR></TABLE>
I know for sure it's not the slave as it's new, but there is a sqeak noise coming from inside the tranny whenever the clutch pedal is depressed and so i'm thinking either it's the pivot point/fork or the pressure plate. Thanks for the reply! 8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">i have a noob question, what kind of fluid is used in the clutch master cylinder?</TD></TR></TABLE>
You can use any brake fluid dot 3 and up. I personally use Motul DOT 5.1. 8)
Old Jul 23, 2006 | 02:42 PM
Hybrid_Coupe's Avatar
well i havent posted anything about what happened to mine so ill tell you...
I was running the 2MD for about 2 years, held up well...until i started making over 600hp. I took it out to the track...and the clutch pedal stuck to the floor...coasted through the traps, put it on the trailer and took it home...cause i knew the clutch was toast. Took it apart, and i had broken the pressure plate in 3 spots. Just looks like they dont hold up to higher hp. lol
Old Jul 23, 2006 | 06:51 PM
mRek9R's Avatar
Default Re: (Hybrid_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">well i havent posted anything about what happened to mine so ill tell you...
I was running the 2MD for about 2 years, held up well...until i started making over 600hp. I took it out to the track...and the clutch pedal stuck to the floor...coasted through the traps, put it on the trailer and took it home...cause i knew the clutch was toast. Took it apart, and i had broken the pressure plate in 3 spots. Just looks like they dont hold up to higher hp. lol</TD></TR></TABLE>
DAMN! I hope I never experience that ^^. 8)
Old Jul 24, 2006 | 08:45 AM
yee SERIOUS's Avatar
my 2ks seems to do ok.
i was at boti a couple weeks ago...after my 3rd run and i was going up for my 4th, i decide to turn the car off for a bit, after that, the car decided not to turn back on. i was getting fuel and spark, but the car just wouldn't catch. i left it on the side for about an hour and it started back up like nothing. but i don't think that'd be a clutch problem? or could it?
Old Jul 24, 2006 | 09:59 PM
mRek9R's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">my 2ks seems to do ok.
i was at boti a couple weeks ago...after my 3rd run and i was going up for my 4th, i decide to turn the car off for a bit, after that, the car decided not to turn back on. i was getting fuel and spark, but the car just wouldn't catch. i left it on the side for about an hour and it started back up like nothing. but i don't think that'd be a clutch problem? or could it?</TD></TR></TABLE>
hm...that's a wierd one. I'm not sure! 8)
Old Aug 31, 2006 | 06:19 PM
mRek9R's Avatar
UPDATED! 8)
Old Aug 31, 2006 | 10:37 PM
riceball777's Avatar
i run the 2ms with about 400whp 300wtq with no problems what so ever. i also have heard that the kevlar dick last forever but doesent hold up well to heat or abuse and will start to slip after its gets hot. thats why i went with the 6 puck
Old Aug 31, 2006 | 10:51 PM
98vtec's Avatar
moderator emeritus
Default Re: Action 2KS clutch owners!(or anyone) Do you have this problem? (riceball777)
not forced inducted, but im running it on my lude and so far its holding up great.....although its only got 600 miles on it
i've gone out and one run after run after run and it never slips, but im not running near the power you guys are.
Old Sep 1, 2006 | 01:02 AM
ThePunk's Avatar
Default Re: Action 2KS clutch owners!(or anyone) Do you have this problem? (98vtec)
We had the same clutch, and the exact same problem in the wifes boosted GSR.
Kevlar clutches for the lose.
Old Sep 5, 2006 | 06:13 PM
mRek9R's Avatar
Default Re: Action 2KS clutch owners!(or anyone) Do you have this problem? (ThePunk)
Yea, I'm starting to like this 2MD...starting to get used to it! Engagement is kinda harsh...but it GRABS!
85camocivic
Transmission & Drivetrain
Mar 15, 2011 06:34 PM
new_climber
Apr 2, 2008 11:38 AM
Tru2Less
Mar 9, 2008 02:26 PM
sohctodohc
26
Oct 3, 2005 10:10 PM
Bbasso
Oct 28, 2003 01:01 PM
