Oil pump location?? CODE 54-Crank Speed Sensor Where is this sensor??
Ok...I have a problem on my 97 GSR ODB-II...I get error code 54 (Crankshaft speed sensor). I've heard this sensor is on the oil pump...Is this true? If so, where is the oil pump located?
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
its behind the crank pully, your going to have to take it off to get to it.
It's on the front end of the block, behind the timing belt sprocket on the crankshaft.
Remove drive belts, remove crank pulley, removing timing belt, remove crankshaft sprocket, and you'll see the oil pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">It's on the front end of the block, behind the timing belt sprocket on the crankshaft.
Remove drive belts, remove crank pulley, removing timing belt, remove crankshaft sprocket, and you'll see the oil pump.</TD></TR></TABLE>
Damn....this sounds like alot of work...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenteg »</TD></TR><TR><TD CLASS="quote">Can anyone confirm the location of the Crankshaft speed sensor??</TD></TR></TABLE>
why do you need confirmation? more than one person told you where it was. anyway, it's not THAT much work, just a bit of time.
rrmaron
Dec 4, 2011 11:54 PM
