d16z6 obd0-obd1 questions
Old Jul 21, 2006 | 05:14 PM
d16vtecx's Avatar
Default d16z6 obd0-obd1 questions
Right now i have a sohc vtec in my 88 hf running off a stock pr3
my vtec is working and i have no codes
i am getting a p28 ecu and obd0-obd1 conversion harness
few questios
Do i need to return my wiring back to stock?
Can i keep my obd0 distributor?
Will the p28 ecu throw a code for vss?
If so, how can i fix it?
Which o2 sensor should i use? (i have a single wire o2 right now)
Is there anything else i need?
thanks for the help
Old Jul 21, 2006 | 05:32 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: d16z6 obd0-obd1 questions (d16vtecx)
you need and obd1 distributor. (td-42u I think)
the ecu won't throw a code for vss.
you will need a 4 wire 02 sensor.
and I don't know what wiring changes you have done to your car, just follow the instructions on the conversion harness you'll figure it out.
Old Jul 21, 2006 | 08:33 PM
d16vtecx's Avatar
Default Re: d16z6 obd0-obd1 questions (ILcrxsi1)
are you sure about the vss?
cuz i had a 95 civic and d15b vtec and it had a code for vss until i replaced the sensor
Old Jul 21, 2006 | 11:36 PM
d16vtecx's Avatar
Old Jul 22, 2006 | 12:28 PM
d16vtecx's Avatar
anyone else?
Old Jul 22, 2006 | 01:01 PM
SVOboy's Avatar
I had the vss code also, I replaced mine with a digital vss and teggy cluster.
Old Jul 22, 2006 | 01:18 PM
ILcrxsi1's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">I had the vss code also, I replaced mine with a digital vss and teggy cluster.</TD></TR></TABLE>hmm never heard of that throwing a code, but I'm not sure. I'm using a p08
Old Jul 22, 2006 | 02:36 PM
SVOboy's Avatar
Fudge, Iono why it did, but it only did while braking in gear or some **** like that...I couldn't figure out when and what would cause the cel to come on to a certainty.
Old Jul 22, 2006 | 02:49 PM
91SiZ6's Avatar
As my name would suggest, I have a '91 Si hatch with an OBD converted Z6. I'm using a P28 with the stock VSS and my speedometer works just fine.
You'll need to return your wiring to stock in order to run a conversion harness.
For a Cali legal OBD swap you'll need...
Conversion harness
OBDI Distributor
4-wire O2 sensor
OBDI injectors with grey clips
P28 ECU
Old Jul 22, 2006 | 05:39 PM
d16vtecx's Avatar
Default Re: (91SiZ6)
so i should keep the cable vss ?
and how do i wire the o2 sensor?
thanks for all the help
keep the info coming
Old Jul 23, 2006 | 04:54 AM
91SiZ6's Avatar
Yeah, your cable VSS will work. If mine works, yours will work.
Get your conversion harness from RyWire.com...they used to be the JKOBD.com conversion harnesses. All the instructions you need come with it. Mostly plug and play with a small amount of wiring on your part. The harness comes with a subharness to put through the firewall for the O2, VTEC, and other various sensors. I taped off the wires I didn't need and soldered some spare two and four prong plugs onto the end of it after putting it through the fire wall and then made my own RyWire-like VTEC/O2 subharness.
Old Jul 24, 2006 | 03:08 PM
d16vtecx's Avatar
thanks
vtec25
May 11, 2011 09:13 AM
xkrazyxjbrkerx75
19
May 18, 2010 04:11 PM
Coltmorris
20
Mar 8, 2009 08:42 AM
meanTheDope
26
Sep 28, 2004 11:37 AM
NotPhilTran
Mar 26, 2004 07:48 PM
