HI LOW converter question about the remote wire
Old Jul 21, 2006 | 04:18 PM
A R M E N .'s Avatar
Default HI LOW converter question about the remote wire
when your hooking up a high low converter to a stock headunit example{pontiac G6}....where d you connect the remote wire to?
Old Jul 21, 2006 | 04:28 PM
02 accord's Avatar
Default Re: HI LOW converter question about the remote wire (A R M E N .)
Antenna output from the head unit.
Old Jul 21, 2006 | 07:28 PM
8520's Avatar
Default Re: HI LOW converter question about the remote wire (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Antenna output from the head unit.</TD></TR></TABLE>
Depends on whether it's a factory amplified system or not. If not I'd use the rear speaker leads (ie non crossed over). If it is factory amplified try and find a full range signal, but if you can't then use the factory sub leads.
Used the factory sub leads on my buddies 99 TL and it worked just fine
*edit* scratch that, I misread. I must say that I don't get it though, maybe it's just been a long day
Modified by a_s_ol_ at 8:46 PM 7/21/2006
Old Jul 21, 2006 | 07:31 PM
bpr0422's Avatar
Default Re: HI LOW converter question about the remote wire (a_s_ol_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ &raquo;</TD></TR><TR><TD CLASS="quote">..........?
Used the factory sub leads on my buddies 99 TL and it worked just fine </TD></TR></TABLE>
umm u mis read asol...
he was talking about the remote turn on lead...
connect it to the power ant lead...
Old Jul 21, 2006 | 08:09 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">umm u mis read asol...
he was talking about the remote turn on lead...</TD></TR></TABLE>
And you misread, noob... He asked about where to connect the remote wire on a stock head unit.
Well, to answer your question, usually, you would use the switched power lead in the radio harness. But since that car does not have a switched power lead (like most newer GM's), you need to tap switched power somewhere else. Check the fusebox; there may be a free accessory pin there. If all else fails, you can tap the ignition harness... Please note that using a switched source like the ignition harness or fuse box sometimes can result in a turn on thump or pop...
Old Jul 21, 2006 | 09:33 PM
bpr0422's Avatar
Default Re: (B18C_EJ8)
yeah.. i'm a noob...
i just thought...
if ur hooking up an aftermarket head... using a harness...
the radio harness would have the power ant lead...
so i thought u just connect it to the power ant lead, for remote turn on...
then again.. i don't know much bout gms... or anything really
Old Jul 22, 2006 | 04:34 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">yeah.. i'm a noob...
i just thought...
then again.. i don't know much bout gms... or anything really</TD></TR></TABLE>
No, when hooking up an aftermarket head unit, you would use the "remote turn on" lead. The power antenna lead is only active when the radio is on.
But for fvcks sake, he's hooking up a converter to a stock head unit!!!
Old Jul 22, 2006 | 06:42 AM
fcm's Avatar
fcm
Old Fart
Wire it to the 2nd ign. output on the fuse box, or connect it to the oem radio harnesses acc. lead, or as has been mentioned to an oem amp turn on lead, if the HU has one. 94
teejlc
Audio / Security / Video
11
Apr 24, 2007 02:21 PM
alien6067
Feb 16, 2005 05:38 PM
volkdlr
Nov 8, 2004 10:46 AM
bigfatchien
Oct 25, 2004 10:44 AM
hatch808
Jun 27, 2003 02:51 AM
