Remote wire lead is reversed. please help
Old Oct 22, 2004 | 02:30 PM
bigfatchien's Avatar
Default Remote wire lead is reversed. please help
has anyone had a problem with their remote wire on their aftermarket HU turning the amp ON when the radio is off and shutting the amp OFF when the radio is on? the wire has power and is doing what it's suppose to do, just opposite.
Old Oct 22, 2004 | 06:00 PM
D'Ecosse's Avatar
Default Re: Remote wire lead is reversed. please help (bigfatchien)
too weird!
When does the wire have voltage - when the head is on or off? It should have voltage when the head is <U>on</U> - if it is the other way around, the head unit is the problem. If it is correct (head on, remote wire has voltage out) then there is a problem with your amp if is being turned off in that state.
Old Oct 23, 2004 | 07:00 PM
Default Re: Remote wire lead is reversed. please help (D'Ecosse)
the wire has voltage when the head is off. the amp is brand new so it should be fine. is there another wire i can hook the amp to besides the remote lead??
Old Oct 23, 2004 | 07:06 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigfatchien &raquo;</TD></TR><TR><TD CLASS="quote">the wire has voltage when the head is off. the amp is brand new so it should be fine. is there another wire i can hook the amp to besides the remote lead??</TD></TR></TABLE> If you have a Honda/Acura you can use the acc. freepin on the fuse box, only has power when ign. is on. 94
Old Oct 23, 2004 | 09:45 PM
D'Ecosse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigfatchien &raquo;</TD></TR><TR><TD CLASS="quote">the wire has voltage when the head is off.</TD></TR></TABLE>
Then either the head is defective, or more likely you are possibly using the wrong wire - the typical color for the remote out is blue
What brand/model head is it? Maybe we can confirm for you ....
Old Oct 24, 2004 | 12:32 AM
its an old pioneer deh-p835r. i'm running it from the blue wire. it worked fine for the 1 day or so but just recently it started doing it.
Old Oct 24, 2004 | 02:44 AM
jdmotorsports's Avatar
check the white with blue wire. it might stay on the whole time with the radio for power antenna. or just use the red wire and splice the radios red wire and the turnon to the amp. it'll keep the amp on while the ignition is on, but thats no big deal.
Old Oct 24, 2004 | 06:20 AM
D'Ecosse's Avatar
Yes, Blue/White would be the correct wire for the remote on on Pioneer systems
Old Oct 24, 2004 | 09:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: (D'Ecosse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D’Ecosse &raquo;</TD></TR><TR><TD CLASS="quote">Yes, Blue/White would be the correct wire for the remote on on Pioneer systems</TD></TR></TABLE>The standard on 99% of HU now is blue, for power ant. only powered when radio is on and blue/white, amp turn on, powered whenever HU is on. There were a few HU that had a neg trigger output also, [Mazda power ant.] haven't seen one, [neg trigger out] in a few years. 94
Old Oct 25, 2004 | 10:44 AM
Default Re: (fcm)
ok thanks guys. i just gonna run my amp from another wire.
AndrewM90
Audio / Security / Video
Sep 12, 2012 08:26 PM
sasser43
Jan 4, 2007 05:13 PM
tdcdodger
Mar 29, 2005 02:04 PM
projectcivicsl
11
Mar 25, 2005 08:29 PM
turbomonkeyexpress
Jan 2, 2003 01:55 PM
