Cutting Springs
Old Jul 21, 2006 | 01:56 PM
lcjarrett's Avatar
Default Cutting Springs
If I cut my Eibach Springs will the ride be different...? I am asking this question because I am broke right now but I want to drop my car even lower then it already is, but I can't afford coilovers right now....Help Me
Old Jul 21, 2006 | 01:57 PM
BALLIN H22 EK's Avatar
Default Re: Cutting Springs (lcjarrett)
different people will say different things.... some people say there ride is smooth some people say the ride is bouncy
Old Jul 21, 2006 | 02:02 PM
lcjarrett's Avatar
Default Re: Cutting Springs (BALLIN H22 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK &raquo;</TD></TR><TR><TD CLASS="quote">different people will say different things.... some people say there ride is smooth some people say the ride is bouncy </TD></TR></TABLE>
I am only going to cut an inch or inch an a half off the springs.....
Old Jul 21, 2006 | 02:17 PM
Harryflores's Avatar
I heard about Cutting Springs - hopefuly comes up good!
Old Jul 21, 2006 | 02:23 PM
philosofy1's Avatar
i once cut my intrax springs and noticed it was more bouncy then before. not to mention they don't sit right in the strut.
Old Jul 21, 2006 | 02:28 PM
Earthworm Jim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcjarrett &raquo;</TD></TR><TR><TD CLASS="quote">If I cut my Eibach Springs will the ride be different...? I am asking this question because I am broke right now but I want to drop my car even lower then it already is, but I can't afford coilovers right now....Help Me</TD></TR></TABLE>
Be patient and wait it out. Do things the safe way not the fast way.
James 1:4
Old Jul 21, 2006 | 02:33 PM
MAX PAYNE's Avatar
Sometimes the cheaps way leads to the most expensive repair. Better safe than sorry. On cutting springs
Old Jul 21, 2006 | 04:34 PM
SavEM1's Avatar
There is actually a right way and a wrong way to cut springs. Cutting a spring the correct way will get you a normal ride but a lower ride height. The wrong way, well, you know. I don't know the procedure as i'd never cut springs my self anyway.
Old Jul 21, 2006 | 04:41 PM
Sketch_hs's Avatar
NO!
buy some used coilovers, i got my tokiko illuminas and GC coilovers for only 300!
DONT CUT/HEAT springs
Old Jul 21, 2006 | 04:43 PM
Sketch_hs's Avatar
Oh and by the way, cutting the springs will lower the car and make the ride stiffer/bouncy ALWAYS WITH NO EXCEPTIONS THIS IS THE RULE!!!
Old Jul 21, 2006 | 04:46 PM
ekb16's Avatar
it might mess up ur alignments also..my cousin cut his springs on his rex and its all messed up...he cant even correct his alignment nemore unless he gets new springs
Old Jul 21, 2006 | 06:39 PM
Projekt_2nr's Avatar
Default Re: (ekb16)
if your gonna cut the spring make sure you have a welder hand for this to correct spring allignment, cut the flat top off of the springs with a hand saw then cut what you want off but add a half of an inch to allow you to wend back on the to cut piece, then weld on the top so it sits directly in position of the shock, now you will have your lower ride it will feel just like a coil over set with out the adgusting plates we did it to an ek once and it made a huge difference than just cutting the springs
Old Jul 21, 2006 | 06:52 PM
-Todd-'s Avatar
lol Hell yeah it will ride different. Dont cut your springs.
Old Jul 21, 2006 | 07:07 PM
FalkenSiR's Avatar
Default Re: Cutting Springs (-Todd-)
if the spring rates are too low then it's going to be the same as cutting stock springs, ride is fine until you hit a pothole...
Old Jul 21, 2006 | 08:35 PM
Sketch_hs's Avatar
in other words, save up a little cash and grab some coilovers
kelviiv
Suspension & Brakes
Feb 8, 2008 05:24 PM
young-richie
Suspension & Brakes
Aug 28, 2007 06:51 AM
Vtechhomie5689
Oct 3, 2004 01:36 AM
1ntensiveVTECivic
21
Aug 6, 2003 12:48 PM
Crxlsturbo
Jul 14, 2003 10:29 PM
