Energy Shifter Bushings
Old Jul 21, 2006 | 08:59 AM
poisonousbeef's Avatar
Default Energy Shifter Bushings
I just put a B&M short shifter in my EK and I used the Energy bushings but I get a lot of vibration noise from the shifter when I'm just cruising. Everything looks tight underneath so I can't figure out what the problem is. Anyone else have this experience?
Beef
Old Jul 21, 2006 | 09:02 AM
BlueIntegraBoy's Avatar
Default Re: Energy Shifter Bushings (poisonousbeef)
Vibration is due to the bushings.
Old Jul 21, 2006 | 09:07 AM
Ok yeah I was under that assumption at this point, hence the title of the thread, but my question is whether or not anyone knows how to resolve it.
Old Jul 21, 2006 | 09:09 AM
Default Re: (poisonousbeef)
Switch back to OEM bushings. The ES ones are stiffer, hence less play = more vibration.
Old Jul 21, 2006 | 09:20 AM
MonkeyBoy668's Avatar
Hrm. I have poly bushings in my shifter and don't have any noise.
Well, not anymore. When my **** comes loose, it's noisy. When I had a **** that didn't come with a rubber/pvc boot to fit over the end of the shifter, it was noisy. But for the moment - it's not noisy. Vibrates like a mother, but no noise.
You could check to see if the noise is coming from your **** by removing it temporarily. If the noise is coming from the joints in the shift linkage, you could try tightening them up. If it's coming from the OEM boot (there's a plastic ring up top that rests against the widening width of the shifter), you could replace it with one that mates up to the shift ****.
It's definitely going to vibrate, but if everything's tight then there shouldn't be any noise. The trick is figuring out what's loose & vibrating.
Vender-
Transmission & Drivetrain
Jan 26, 2013 06:21 PM
Nicks95GSR
Mar 24, 2007 04:51 AM
SiKSi2K
Nov 8, 2004 08:31 PM
xaznx
Nov 1, 2002 10:12 AM
gsr squirrel
Jan 4, 2002 10:33 AM
