D15b Vtec help!!! cant get to stop pulsing!!
Old Jul 20, 2006 | 06:57 PM
EFwithS2000taillights's Avatar
Default D15b Vtec help!!! cant get to stop pulsing!!
Ok here is the deal, I did a DPFI to MPFI conversion on my 89 civic dx. I put in a D15B vtec motor, and I am running a crx si computer. The problem is, that it will run but it back fires alot, and at 2k RPM's it pulses really bad. Like it is hunting or somethin. I have checked all my wiring many times, but cant figure it out..I even tried a different ecu. Please help!!!
Old Jul 20, 2006 | 07:11 PM
STDClayton's Avatar
Default Re: D15b Vtec help!!! cant get to stop pulsing!! (EFwithS2000taillights)
i'm not insulting you when i ask this, but do you have any check engine lights?
Old Jul 20, 2006 | 07:17 PM
ILcrxsi1's Avatar
I tell doctors what to do
what distributor are you using?
Old Jul 20, 2006 | 07:30 PM
Yes I have many check engine codes. I have the following codes...TPS, TDC, IACV, CRANK SENSOR, and number 9? I am also using a b18a distributer...so you know.
Old Jul 21, 2006 | 06:04 PM
Ok now I got it running good at idle. I have a number 4 code, which is the crank sensor. I still am having problems though like pulsing when I hit the throttle and delayed throttle reaction. please help!!
bOOsT-FeIn
Sep 26, 2006 04:24 PM
Jul 25, 2006 07:52 AM
zc@hybrid
Apr 20, 2004 04:27 PM
88CRXSWAP
Oct 21, 2003 12:15 PM
blacksoul
Sep 10, 2002 08:25 AM
