B18A/B Manifold & Throttle body compatibility (No map sensor)
I mated my B18B (94 Integra) throttle body to a B18A intake manifold (As far as I know it is a B18A manifold).
I suspect I am suffering from severe vacuum leak due to this. The throttle bodies ARE different in design in regards to placement of the FITV and such. Anyhow I tried to put the B18A throttle body back on it's B18A intake manifold and now i see that there is NO map sensor, nor is there a spot where I could even mount the one off my B18B throttle body.
Is there a solution here? Or should I drain the coolant and swap intake manis (An option I'm not too fond of, but I will if it is the best option).
The ECU I am running is a 94 LS map...
Takumi Fujiwara
Jul 20, 2007 08:50 AM
b18a, b18bthrottlebody, body, bodys, compability, compatibility, fit, h22, honda, integra, manifold, map, sensor, spot, throttle
