power window motor
Old Jul 20, 2006 | 03:49 PM
JDMegCoupe's Avatar
Default power window motor
Okay this is for a 95 coupe. Right now my window motor seems like it's about to give up on me and die and then at times it seems fine and some times it'll go up slowly. But just woundering would it be possible to swap motors with a newer year like 96-00 window motor or no? Or just need some oil to the motor? Thanks
Old Jul 20, 2006 | 08:43 PM
jdeemseerx's Avatar
you can try lubing up the window tracks, but most likely your motor is going out on you, and i dont believe EKs are the same as EG but i could be wrong
Old Jul 20, 2006 | 10:17 PM
jclamor87's Avatar
Default Re: power window motor (JDMegCoupe)
would you happen to know how to convert manual windows into power windows
Old Jul 21, 2006 | 09:38 AM
jdeemseerx's Avatar
yes i do! but i also know how to search
Old Jul 21, 2006 | 03:01 PM
JDMegCoupe's Avatar
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">most likely your motor is going out on you, and i dont believe EKs are the same as EG but i could be wrong</TD></TR></TABLE>
Anyone else????????????????
Old Jul 22, 2006 | 08:27 AM
hatchi's Avatar
no they are not interchangeable. but try lubing your window tracks and see if that makes a difference
Old Jul 23, 2006 | 11:49 AM
JDMegCoupe's Avatar
Default Re: power window motor (hatchi)
so if I try lubing it and if it dies on me what are my opions then? No window/ power window unless I buy a motor from junk or somthing to replace it? OR is there anybody that makes "newer motors" for this kind of situation. Most likely junk eh? All right thanks, will have to do.
Dub C
Oct 8, 2010 05:49 PM
E.Honda
Mar 7, 2006 01:14 AM
dexterX51
Apr 6, 2005 05:35 PM
SonicGSR
May 22, 2003 07:16 AM
Gennady
Jun 18, 2002 05:23 PM
