Rough grinding feel from clutch
Old Jul 20, 2006 | 11:55 AM
CH2iS*'s Avatar
Default Rough grinding feel from clutch
i've got a '94 EG2 and i just finished an overhaul on all the gaskets for the head. theres still an idle problem but i think i know what i need to do with that to solve it. my question is about the clutch. i noticed that if i press down on the clutch pedal just lightly about an inch down and hold it there i can feel and hear some kind of noise which sounds like grinding. what's wierd is the clutch pedal when depress i can't really hear it or feel it. other then that the clutch grabs fine and doesn't seem to be going out. i would like opinions on this matter before i start taking off the tranny to look at whats making the sound and feel. oh, and just yesterday i changed the oil in the tranny and it got a little better but still a hint of it still there. when i drive on the freeway over 60MPH i can really here that grinding sound from the cockpit. what do you think it is?
Old Jul 20, 2006 | 03:25 PM
bnoland's Avatar
Default Re: Rough grinding feel from clutch (CH2iS*)
Sounds like a main bearing in the tranny.. last time I had that feeling it was in a jetta and the main bearing was toast in just a couple weeks. You could push it all the way in and felt smooth but just alittle where it just starts to release the pressure plate the peddle would just vibrate at first and then it start to shake up and down.
Old Jul 20, 2006 | 05:58 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 9:35 AM 11/16/2006
Old Jul 20, 2006 | 08:45 PM
CH2iS*'s Avatar
actually i got it backwards. let me correct it. if i press the clutch down the squeeling noise stops. if i release the clutch the squeeling noise starts again. as for the rough grind feeling. well, it's gone. the oil was black and of a water consistency. thank god i decided to drain it to see if it needed changing. i guess previous owner really didn't take care of the mechanical on this car very well.
so what can cause a squeeling sound inside the tranny when clutch is depress?
Old Jul 21, 2006 | 06:22 PM
bnoland's Avatar
Default Re: Rough grinding feel from clutch (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">If it only makes the sound when you lightly press in the clutch pedal, all signs point to your throwout bearing, or a messed up diaphragm spring. Not internal bearings.
Though, it's Not clear from your post if the sound occurs when driving 60 while your foot is off the clutch.</TD></TR></TABLE>
I understand what you are saying and yes that can be it.. that is what I thought on my jetta and when I got the tranny out and the clutch was fine I pulled on the output shaft to find 1-1 1/2 inchs on in and out travel on it. It can be the internal bearings.. drive it till it *****. If you still have one/some gears then its an internal bearing, if you have nothing then its the throw out bearing. I would fix it before it comes to that though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CH2iS* &raquo;</TD></TR><TR><TD CLASS="quote">actually i got it backwards. let me correct it. if i press the clutch down the squeeling noise stops. if i release the clutch the squeeling noise starts again. as for the rough grind feeling. well, it's gone. the oil was black and of a water consistency. thank god i decided to drain it to see if it needed changing. i guess previous owner really didn't take care of the mechanical on this car very well.
so what can cause a squeeling sound inside the tranny when clutch is depress?</TD></TR></TABLE>
If it is just squeeling then that is probably the throw out bearing.
Old Jul 21, 2006 | 08:38 PM
CH2iS*'s Avatar
Default Re: Rough grinding feel from clutch (bnoland)
thanks for the suggestions and advice guys. i'll have to tear it apart once i get a chance.
project-boosteD
Transmission & Drivetrain
Jul 31, 2010 01:52 PM
Rick James
11
Nov 4, 2008 07:00 PM
aznsins88
Sep 17, 2004 02:42 PM
Hung
Apr 28, 2002 06:17 AM
