radiator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGdrop6 »</TD></TR><TR><TD CLASS="quote">if u leak radiator coolant what does it mean. i fill up and it wont last for like a couple weeks.</TD></TR></TABLE>
uhhh could you elaborate? could be a variety of things
I noticed a couple coolant puddles under my hood a week ago (around radiator and stock airbox.) I was asking around if people thought it was a hose leak or a radiator leak. Well it started to overheat this Monday on my drive to work. Once it got to that extreme there was a big puddle of coolant under the car and we could see a spray from the radiator. I got it replaced for $75 for my 95 EX.
I suggest you elaborate so you can get it taken care of before it ends up overheating.
It is either leaking from somewhere (such as hose, radiator, water pump), or you have a bad head gasket and you are burning it.
if you leak coolant, that means that there's leak somewhere in your cooling system, eventually causing your car to overheat...figure out where it's leaking from and fix it...it could just be hoses but if it doesn't get fixed, it could turn into something serious...
fms1day
May 24, 2007 02:46 PM
ILcrxsi1
Mar 29, 2007 03:14 PM
slikz714
Jul 12, 2006 03:40 AM
missionaryrider
Jun 21, 2005 09:19 PM
