swap questions
Old Jul 19, 2006 | 05:25 PM
wildryders01's Avatar
Default swap questions
I have a 92 accord.I have a d15-z1 and would like to swap it into the accord i know the trans won't mount but i have complete swap will it bolt in?If the k-frame is different i have a k-frame from a 92 hatch will it all bolt in?The trans i have is hydro so i have everything to convert but will it all bolt in.Thanks for your time
Dave
Old Jul 19, 2006 | 07:01 PM
92ehatch's Avatar
Default Re: swap questions (wildryders01)
i could push your car faster than a d15 would get it moving.
it is absolutely pointless to put that engine in, it does not have nearly the amount of torque or hp to get the car moving.
your car weighs rougly 2800lbs, you need to stick with the f22's
d15 - 92hp/97tq
f22a1 (lx motor) 125/137 (i believe)
if price is an issue look into a jdm f22b (its a dohc non vtec, very similar to h23)
Old Jul 20, 2006 | 03:19 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: swap questions (93cb7sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan &raquo;</TD></TR><TR><TD CLASS="quote">you need to stick with the f22's</TD></TR></TABLE>
well, not just F22's. Any F or H series motor will be fine, excluding the S2000 motor of course.
Not only does the D series motor not have enough torque, they won't mount into your car without custom motor mounts. Also, you would need to swap your shifter mechanism to the rod style that the D and B series motors have. The swap just isn't worth it.
For 90+ Accords, stay with the F or H series motors. Leave the D and B series motors to the Civic's and Integra's.
If you looking for more power bnut don't have a lot of money, you could sell that D15 you have and buy a H22 or H23 head. For more info on swaps, take a looks at the "Swaps" section in the Accord FAQ.
Old Jul 20, 2006 | 04:11 AM
KillerElfboy's Avatar
Default Re: swap questions (TouringAccord)
Touring Accord has it. If you can work it, you might be able to sell whatevers under you hood now and that D engine and get a nice H22
altho i think a lot of ppl here will tell you sell that D series and put it in your piggy bank towards a turbo setup if you want some real power
Old Jul 20, 2006 | 04:33 AM
khunt0012's Avatar
Meat Robot Invisible
No torque, no care.
AcCoRdKiD916
Northern California
Feb 26, 2010 09:38 AM
1sickef9
Nov 16, 2009 05:24 PM
darvin
Jan 3, 2008 11:07 AM
TALDRIDGE85
Jan 27, 2007 12:38 PM
IcebergMan
14
Jan 20, 2006 04:09 PM
