Studdering and won't start
I'm helping a friend with this 87 acura integra LS, she had a coolant leak and the car ran hot. SHe said it never got into the red. Well I put some fluid in it, took 3/4 of a gallon, then the temp was good. Now when i went over say 1/3 throttle, it would studder very badly but won't die, this would happen at the same point every time. On the way home it got better, so when I got here I let it cool and hosed off the motor, covering the distuributer. Now the car won't start. It just cranks. I look at every connection I could see under the hood to see if they were loose but nothing. I pulled the distuributer car to check for water, just in case, but none. I'm new to honda's so I didn't know if this had happened to anyone else here and maybe has a good idea what it is. Thanks
crazybluecivic
Honda Civic (2001 - 2005)
Mar 18, 2010 05:55 PM
zam-pa-te-es-te
Oct 9, 2005 03:32 PM
Any leaks visable?
