b18c burning oil
Old Jul 19, 2006 | 03:34 PM
WhiteNgold's Avatar
Default b18c burning oil
i bought my swap from some guy that told me it had itr internals and never was boosted or sprayed on. i installed it and it ran perfect w/ little smoke. i asked why it smoked and he said the valve seals were bad. so i figured id drive it for a little bit b4 i put valve seals in. well..... it got way worse and poured smoke after a awhile(even just revving it a little would blow smoke everywhere. i did a leakdown on it and i could hear it hissing the dipstick tube on cylinder 2. so i bought oem rings and just rerang it saturday.definantly not itr internals. when i pulled out the piston and rod from cylinder 3, it had heat marks on it(the rod). so i figured this guy bullshitted me. i put everything back together by specs and drove it home(after ringing them). ive been putting easy miles on it to break it in since, but latley its been starting to pour smoke when i give it some throttle and let off. ( ex. 3rd gear, 40 to 50mph, 60-70% throttle, not even popping into vtec, and letting off still in gear.) i think its my seals but not too sure. any comments or advice?
Old Jul 20, 2006 | 04:58 AM
WhiteNgold's Avatar
Default Re: b18c burning oil (WhiteNgold)
any comments?
Old Jul 20, 2006 | 09:40 AM
LagunaSecaEG's Avatar
who did u buy the sway from? someone in sarasota?
Old Jul 20, 2006 | 11:00 AM
WhiteNgold's Avatar
Default Re: b18c burning oil (LagunaSecaEG)
no it was someone in hudson, florida. why?
Old Jul 20, 2006 | 11:11 AM
deckster333's Avatar
does it only smoke when in high vacuum? like off throttle down hills and idling? I have heard that could be because if valve seals, sounds like you have other issues too though
Old Jul 20, 2006 | 12:50 PM
WhiteNgold's Avatar
Default Re: b18c burning oil (deckster333)
i dont know anymore, im out of thingsto try. i bought some lucas oil stabilizer to cut down on it and see what it did. i will be putting valve seals in when they get here. maybe the rings arent set yet? i dont know
Old Jul 20, 2006 | 12:51 PM
WhiteNgold's Avatar
i appreciate the advice guys but keep'em comin'. i want tobe able to have this motor for a awhile.
Old Jul 20, 2006 | 12:55 PM
fmrprojects's Avatar
if you replaced the rings, why not replace the seals while the head was off
Old Jul 20, 2006 | 01:26 PM
.I.Need.Money.'s Avatar
Default Re: b18c burning oil (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">if you replaced the rings, why not replace the seals while the head was off</TD></TR></TABLE>
That's what I was thinking.
Old Jul 21, 2006 | 03:53 AM
WhiteNgold's Avatar
Default Re: b18c burning oil (93EGB18C1)
i ordered the valve seals the same time as the rings but the rings got here on time and the seals didnt. i only had saturday to do it. but no worrys, ill just put some compressed air in the cylinders to hold them up.
Old Jul 21, 2006 | 06:00 AM
siregcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteNgold &raquo;</TD></TR><TR><TD CLASS="quote">60-70% throttle, not even popping into vtec</TD></TR></TABLE>
so does your vtec pop like pop corn??? lol
valve guides can be bad.. how do u know they are not itr pistons??? whats the cast number on top of the piston??? ie p72...
my friends car smokes bad.. and i know for a fact its his valveguides because he put a y8 head on his z6 and its been smoking ever since...
Old Jul 21, 2006 | 06:27 AM
WhiteNgold's Avatar
Default Re: b18c burning oil (siregcivic)
itr's are 73 and gsr's are 72, mine is 72. its pretty doubtful that its the guides because it takes alot to warp them. im thinkin seals. they should be here soon
Old Jul 21, 2006 | 06:28 AM
WhiteNgold's Avatar
btw, yeah it pops like popcorn, hahahahaha
Old Jul 24, 2006 | 11:31 AM
WhiteNgold's Avatar
ttt
bad23591
Sep 6, 2014 12:22 AM
slugo10
Dec 2, 2008 07:41 AM
BiG_DeE
16
Feb 9, 2008 11:53 PM
prettylew
45
Dec 16, 2007 06:48 PM
b16ahybrid
May 5, 2003 09:25 PM
