what goes here?
Old Jul 19, 2006 | 12:23 PM
Sic_DA_Nine's Avatar
Default what goes here?
i cant seem to find a harness that reaches to it
so i thought it was this:
but thi is as far as it reaches:
my fan still works...somehow the previous owner wired it up like this:
and the wire leads to this:
i have no idea whats going on now..its starting to overheat during driving...
plase dont same..."thats ***** dumb" or anything since im not the one who did it like this...
the motor is a b20 with a gsr head
Modified by Sic_DC_FOE at 4:19 PM 7/19/2006
Old Jul 19, 2006 | 12:31 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: what goes here? (Sic_DC_FOE)
I don't even think I have anything that goes there, I would guess it's for temp?
What model/year is the engine?
Old Jul 19, 2006 | 12:58 PM
teg91's Avatar
Looks like the coolant temp sensor
Old Jul 19, 2006 | 01:01 PM
jdm_bones's Avatar
Default Re: (teg91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg91 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like the coolant temp sensor</TD></TR></TABLE>
Yup, temp sensor...that goes to your thermostat....
Old Jul 19, 2006 | 02:16 PM
-Kirk-'s Avatar
Default Re: (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, temp sensor...that goes to your thermostat....</TD></TR></TABLE>
Correct, and without it your fan won't come on. I wouldn't suggest leaving your car idling for very long without that plugged up. I've seen a blown motor because of that exact same thing. If you can't find the plug for it I'd atleast wire your fan up where it comes on with the key.
Old Jul 19, 2006 | 02:58 PM
Default Re: (teg91)
the harness doesnt reach that....
my car is starting to overheat :[ freeway and street
Old Jul 19, 2006 | 03:19 PM
added more pics aat the top!
Old Jul 19, 2006 | 03:51 PM
redteg222's Avatar
Default Re: (Sic_DC_FOE)
Does the wiring harness you're using match the head you're using? Also, I saw electrical tape in one of those pics around the wires right behind the connector...was the wire repaired/replaced, and is now shorter than it was? I wired a switch inside the last car I had to turn on the fan whenever I wanted to, but your looks like its wired to something Hot in Run, can you tell what its hooked up to? Is it on all the time? Doesnt sound like its on if you're overheating a lot.
Old Jul 19, 2006 | 03:55 PM
Default Re: (redteg222)
fan is running all the time
Old Jul 19, 2006 | 04:02 PM
rgaray's Avatar
If you have access to a helms, look up the eletrical of the sensor and see if the color listed matches the wires you think.
likwidchz
Engine Management and Tuning
Oct 15, 2009 12:59 PM
JAYDmManny1331
Jul 20, 2009 07:39 AM
NAV_GUNZ
Oct 14, 2008 09:36 PM
BoltonGSR
May 29, 2007 07:58 PM
ek4d00r
Aug 1, 2005 04:12 PM
