hood clearance solutions? pic request
im putting a b18c5 block with a b16 head into a da9. i think its taller than the orignal LS. has anyone had a problem with their hood not closing. im tring to maintain an oem style hood. if the hood didnt clear what was your solution? if you got pics, post em so i could get some ideas if mine doesnt clear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 »</TD></TR><TR><TD CLASS="quote">i have no problem with my b18c1</TD></TR></TABLE>
Then, he shouldn't have a problem with the B18C5.
i havent tried putting the hood on, yet. the new engine just looks alot higher in relation to the strut towers. im also using innovative mounts. could that have made it sit higher?
the whole front of the car is still stripped from when i got it painted, so i havent put the latch back on yet. i guess thats what i need to do, is a test fit. i was kinda wanting to see some pics of some hoods that have been shimed
in order for my poormans ITR to fit i had to bang the skeleton of the hood up a bit, but that went wrong so i shimmed it up abit instead. the very middle of the VC and the timing belt area hits the hood
I have an H2B in my DA and There isn't no way that hood is going to close so I had to do the washer and bolt thing. At first I need 2 1/2 inches of the washers for it to close but I just cut up the hood a little bit and now Im down to one inch. Yours should fit but if it doesnt, it really doesnt look bad and a lot of the time you cant really tell. Good Luck!
