Need info on EG Trunk Light - help!
i have a 92 civic vx. my car didnt have a trunk light so i brought one on ebay but as i've taken off the panel, i cant seem to find the wire for it. could someone let me know if there are already premade wires w/ the connector for the trunk light. let me know.
if its there it should be obvious, my inner quarters are out right now and that wire is about 1~1.5 feet long with a gray connector on the end. if you dont have it you could wire it up easily..... especially if your quarter is out right now. you can catch the hot wire for your domelight behind the drivers a pillar, and catch the hatch pin in the drivers side harness coming from the tailgate. anyway i listed tech sheet below, good luck.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 1992 / Remote Start
[PRINT THIS PAGE]
12volts white + brn conn abv fusebox
Starter black/white + brn conn abv fusebox
Second Starter
Ignition black/yellow + brn conn abv fusebox
Second Ignition
Third Ignition
Accessory yellow + brn conn abv fusebox
Second Accessory
Keysense
Power Lock green/white - in drivers door
Notes: Door lock module in door above the speaker. the wires can also be found at the anti-theft if equiped.
Power Unlock green/red - in drivers door
Lock Motor
Unlock Motor
Parking Lights+ red/black grn plug top of f-box
Parking Lights- white/black anti-theft module
Notes: the anti-theft module is located under the drivers seat. only some models are equiped with anti-theft.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer blue AC 2-pin plug near distr.
Notes: Also at round gray connector next to hood strut.
Wait to start
Brake Wire green/white + brake pedal switch
Parking Brake
Horn Trigger blue/green - steering column
Notes: can also be found blue/red at anti-theft if equiped
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this
[PRINT THIS PAGE]
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
No Type:
N/A
Part #: N/A
Notes:
