which is the better tranny?
which is better for my setup, JDM Y1, JDM S1, or JDM YS1?
I have an EF8, 185whp @ 8800rpm b16a, currently has the non-LSD Y1 tranny.
I finish the 1.4 mile at 9000rpm at 3rd gear with 9k rpm shifts. My tires are 195.55 advan ao32rs. Is it ok? after shifting 3rd gear i feel that my car is not getting any faster. Is it because of the 4.2 FD of the Y1?
I need some opinions. TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex »</TD></TR><TR><TD CLASS="quote">are you n/a or turbo </TD></TR></TABLE>
please god, don't tell me you are about to make a "longer gears are better for turbo" comment
those make baby Jesus cry
with a 185 hp i hope its not turbo
I think you'd know how your car feels the best. If it feels undergeared, then make a change.
It might be more practical just to swap in a lower final drive, most of the gear spacing itself isn't all that different between the close ratio VTEC transmissions.
Obviously, if you swap, make sure you know what you are getting, S1 and YS1 transmissions have wide and narrow spacings, as both were used in LS/RS/GS models as well.
If you want to buy something, the VTEC YS1 cable transmissiosn are the lowest of the factory gearing. 4.4 axles, and the tightest spacing. I'm putting one behind my LS in my 91 hatch in a couple weeks, from a 1992 USDM GS-R.
superhatchbackbros
10
May 30, 2006 10:19 PM
