ls vtec w/p30 pistons
Old Jul 18, 2006 | 08:01 PM
4d96gsr's Avatar
Default ls vtec w/p30 pistons
is a ls vtec with standard p30 piston from a jdm del sol b16 any good for power???
Old Jul 18, 2006 | 08:06 PM
Lan's Avatar
Lan
Default Re: ls vtec w/p30 pistons (4d96gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4d96gsr &raquo;</TD></TR><TR><TD CLASS="quote">is a ls vtec with standard p30 piston from a jdm del sol b16 any good for power???</TD></TR></TABLE>
Yes- p30 pistons are Civic type R I believe. It will up your compression immensely, close to 12.5:1 with a GSR head if you decide to go VTEC
Old Jul 18, 2006 | 09:05 PM
4d96gsr's Avatar
Default Re: ls vtec w/p30 pistons (Lan)
thnkz man
Old Jul 18, 2006 | 09:17 PM
-Championship-'s Avatar
76.169.175.137
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">
Yes- p30 pistons are Civic type R I believe. It will up your compression immensely, close to 12.5:1 with a GSR head if you decide to go VTEC </TD></TR></TABLE>
wow didnt know that, i heard civic type r pistons (pct) on a ls block with b16 head gives out 11.2
Old Jul 18, 2006 | 11:50 PM
jdm_bones's Avatar
Default Re: ls vtec w/p30 pistons (JDM_violator)
CTR piston is called PCT
Del Sol B16 piston is called P30
Old Jul 18, 2006 | 11:57 PM
Dartanian's Avatar
Wrong. PCT pistons are JDM B16B pistons and will yield that compression ratio.
P30 pistons are JDM B16A pistons and will yield around 11.5-11.8:1 static compression depending on what head you are using.
Old Jul 19, 2006 | 07:36 PM
4d96gsr's Avatar
yeah i will be using a b16 head with port & polish and gsr cams type r monifold &some good header with a tuned ecu and will seee what happens thnkaz
Old Jul 19, 2006 | 08:09 PM
jdm_bones's Avatar
Default Re: (4d96gsr)
P73 pistons go well in the LSV set up as well bro...
Old Jul 19, 2006 | 09:48 PM
dohcgarage@714's Avatar
that set up is gonna give you some good power my buddy had the same setup the only difference what the he had the blox manifold but he was making about 180-190 at the wheels
Old Jul 19, 2006 | 10:12 PM
Fat Chick Magnet's Avatar
with 12.5:1 compression do you have to pump race gas or can you use 91?
Old Jul 19, 2006 | 10:35 PM
Dartanian's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">with 12.5:1 compression do you have to pump race gas or can you use 91?</TD></TR></TABLE>
With a good tuner, you may be able to get away with it, but more than likely, you will have to lower it a little more to safely run pump gas.
Old Jul 19, 2006 | 10:40 PM
lVlemphizStylez's Avatar
Default Re: ls vtec w/p30 pistons (dohcgarage@714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcgarage@714 &raquo;</TD></TR><TR><TD CLASS="quote">that set up is gonna give you some good power my buddy had the same setup the only difference what the he had the blox manifold but he was making about 180-190 at the wheels</TD></TR></TABLE>
weak numbers for that setup...ive seen cammed gsr's make that...and bolt on type r's hit 180 whp with a tune
if i had a port matched head with combustion chamber polishing and a 12 to 1 cr...id cry if i broke 180 whp..
Old Jul 19, 2006 | 10:49 PM
jdm_bones's Avatar
Should be OK with 93...
Old Jul 20, 2006 | 08:53 PM
4d96gsr's Avatar
Default Re: (jdm_bones)
yeah sounds good i was looking into doiing 180whp if that but that still alot of power maybe?
Old Jul 20, 2006 | 08:58 PM
bluemax189's Avatar
isnt pr3 ctr pistons?!
Old Jul 20, 2006 | 09:24 PM
Dartanian's Avatar
Default Re: (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">isnt pr3 ctr pistons?!</TD></TR></TABLE>
No, they are USDM B16A pistons. PCT pistons are CTR.
Old Jul 21, 2006 | 12:21 AM
my buddys engine wasnt tuned tho it was running on a chipped gsr ecu
he was gonna go with hondata but he traded his car for a turboed hacth instead
Old Jul 21, 2006 | 02:22 AM
H23 Power's Avatar
Default Re: (dohcgarage@714)
this thread is wack.
just use some PR3's (USDM B16A) or P30's (JDM B16A) because they will yield you 11.x:1 compression and fit on your rods without machine work.
imskatencrzy
Sep 21, 2006 11:17 AM
M2nR
Jun 27, 2006 09:19 PM
Griffin@Camtech
Feb 22, 2006 06:15 PM
RaceCarRyne
Nov 3, 2005 02:19 PM
Big Dick Bandit
13
Sep 16, 2003 05:28 PM
