OBD2 motor swap and inspections
Old Jul 18, 2006 | 04:40 PM
campbuds's Avatar
Default OBD2 motor swap and inspections
I am curious is anyone knows about what might happen with a motor swap (d16y7 to B18b) in a 96 civic?
I would swap in an OBD2 engine. But then I was told by a local guy he is not sure if it would still pass inspection because the inspection stations computer would be looking for a D16 and would find a B18.
Old Jul 18, 2006 | 04:50 PM
ccjustin's Avatar
i was checking with the regisrty about that in mass for my 97. the registry and the E.P.A. told me that as long as the computer thinks the engine is running properly you're fine. it could be a cummins turbo diesel. the only other thing they said i would be fine on but haven't checked is a vin mis-match, but the 98 ex computer i used did not store the vin, that was only the newer ecu's. even if it did end up on a vin mis-match report, they said i would need the car looked at by a registry official (statey) and as long as its all legit you're fine.
raverx3m
Jan 12, 2015 10:55 PM
SpadedEK
10
May 29, 2009 01:22 PM
JDMHondaEJ8
Nov 12, 2006 05:20 PM
pkgwjai082
Jan 31, 2006 12:08 PM
aZnjCC
Jul 9, 2004 05:31 PM
