gross polluter...can someone help?
Here is the diagnostic the emissions station gave me. I also got a pamphlet on what the top ten reasons I failed are. Anyway I failed hydrocarbons and CO but my NOx was fine surprisingly. Any help will be appreciated. I have until November 15th to clean up my act
HC = unburnt fuel
CO = poorly burnt fuel
Could be's
O2 sensor
Air filter
Tune-up
clogged injectors
fuel pressure
If your HC's are up usually the NOx is down. By the way NOx is caused by high combustion temp above 2500 degrees. The HC's keep the combustion temps down.
Could be's
O2 sensor
Air filter
Tune-up
clogged injectors
fuel pressure
Amed Irizarry
11
Dec 4, 2011 07:01 PM
