Stock 94 HONDA ACCORD- at what rpm does t start to hurt the engine?
Old Jul 18, 2006 | 03:10 PM
JonCoop's Avatar
Default Stock 94 HONDA ACCORD- at what rpm does t start to hurt the engine?
i keep seeing that the vtec engages at 5200 rpm... i thought that going past 4000 rpm is harmful for the engine. is it???
if so... what things can be done to make it safer???
thanks
Old Jul 18, 2006 | 03:26 PM
TheMuffinMan's Avatar
He knows where you live!
vtec enables at kinda whenever, it's based off of many variables in the car, it just doesn't go "i'm at 5000 rpm time to start!" and doing it all the time can be, but on occassion no it's fine , but redlining every chance you get not awesome
Old Jul 18, 2006 | 03:32 PM
JonCoop's Avatar
Default Re: (TheMuffinMan)
thanks for the info..
in my car when i get to 5200 rpm in 3rd gear it kicks back down to 4700 rpm... then back up like normal... is this normal or is a bad sign like somethings wrong??
thanks
Old Jul 18, 2006 | 04:32 PM
KillerElfboy's Avatar
Default Re: (JonCoop)
if while you're applying gas yes,
do you mean you're accelerating and i jumps down then back up for it to change gear?
Old Jul 18, 2006 | 09:26 PM
02 accord's Avatar
Auto trans? I heard that if you hold it in 3rd, it goes into lockup. That would explain your rpm drop, and yes that would be normal.
Old Jul 18, 2006 | 10:17 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">vtec enables at kinda whenever, it's based off of many variables in the car, it just doesn't go "i'm at 5000 rpm time to start!" and doing it all the time can be, but on occassion no it's fine , but redlining every chance you get not awesome</TD></TR></TABLE>
for 5th gen? i don't even know they have variable vtec crossover.
i think the ecm would allow vtec to cross-over when the a set rpm is reached and the check list is a go(oil pressure, temp, vss, etc)
Old Jul 19, 2006 | 05:05 AM
Variables meaning what you listed there, i was kinda of unclear I guess and can see what you're saying. The better way to word it would be to say that after meeting all the conditions necessary it will enable - obviously it wouldn't enable at 2000 rpm which I guess could be intrepretated from my post
Old Jul 19, 2006 | 05:39 AM
TouringAccord's Avatar
H-T Order of Merit
It's always been my understanding that the VTEC engagment point on the F22 varies due to certain parameters being met.
edit:
I found this from a quick search...
https://honda-tech.com/zerothread?id=1656616
Old Jul 19, 2006 | 06:02 AM
msedacca's Avatar
Default Re: (TouringAccord)
I would just like to give an example of what one of my friend's has said, a Acura Tech:
Shad0w K24: redline is another word for "this is where i blow up"
Shad0w K24: thats why they call it the "redline" instead of the "i dont give a crap cross me anyday line"
Old Jul 19, 2006 | 11:23 AM
JonCoop's Avatar
Default Re: (KillerElfboy)
HEY,
YES ITS A AUTOMATIC AND WHEN I HAVE IT IN 3RD ITS GETS TO ABOUT 5200RPM THEN DROPS TO 4700RPM THEN STARTS GOING BACK UP AGAIN
Old Jul 19, 2006 | 01:50 PM
H-T Order of Merit
turn your caps lock off
Old Jul 19, 2006 | 10:45 PM
ilikehonda's Avatar
theoreticly at 1rpm you begin to hurt the motor just very very very slowly
marehmanshoaib
Honda City
Dec 26, 2017 12:28 AM
xkrntamax
Honda Civic (2006 - 2015)
11
Jul 19, 2008 03:02 AM
davey5300
Feb 4, 2008 04:52 PM
navysealsnypre
May 25, 2007 09:12 AM
