LS motor in hatch (compression question)
Old Jul 18, 2006 | 02:41 PM
1sick4dr.'s Avatar
Default LS motor in hatch (compression question)
ive been a member here for a few months and ive always had friends with hatches but never had the chance to own one myself, well i have finally got my hands on a 94 dx charcol grey hatch, ive got an LS for it, but the block internals need to be rebuilt, id like to build it all motor no turbo/nos, anybody got a good compression ratio that i should go for? or a short list of block internals would be great im looking to get about 350+ whp at least, and ive got an ok amount of money but not alot, any help is appreciated
Old Jul 18, 2006 | 02:43 PM
G2 Speed's Avatar
Default Re: LS motor in hatch (grandman17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandman17 &raquo;</TD></TR><TR><TD CLASS="quote">ive been a member here for a few months and ive always had friends with hatches but never had the chance to own one myself, well i have finally got my hands on a 94 dx charcol grey hatch, ive got an LS for it, but the block internals need to be rebuilt, id like to build it all motor no turbo/nos, anybody got a good compression ratio that i should go for? or a short list of block internals would be great im looking to get about 350+ whp at least, and ive got an ok amount of money but not alot, any help is appreciated</TD></TR></TABLE>
Forget it then, at least if your going that route.. get a vtec head
Old Jul 18, 2006 | 02:47 PM
FalkenSiR's Avatar
The OP is contradicting himself. If you are going all motor, then your best bet is K20, not the lowest powered B series motor, the LS.
Boost is going to be cheaper and it's going to give you more power. I don't see an LS making 350hp+ in NA form
LS will be lucky if it makes over 200 whp in na form
Old Jul 18, 2006 | 03:45 PM
1sick4dr.'s Avatar
oh ok, i gotcha i guess ill look into low compression with a turbo then for the LS?? rite? i already have the LS motor/tranny but the block internals need replacing on the block and i guess i could go turbo, whats the lowest comression i could go and still drive while i save up for turbo thats my next ??
G2 Speed's Avatar
Default Re: (grandman17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandman17 &raquo;</TD></TR><TR><TD CLASS="quote">oh ok, i gotcha i guess ill look into low compression with a turbo then for the LS?? rite? i already have the LS motor/tranny but the block internals need replacing on the block and i guess i could go turbo, whats the lowest comression i could go and still drive while i save up for turbo thats my next ??</TD></TR></TABLE>
get rid of the ls tranny
Old Jul 18, 2006 | 03:51 PM
leeminho86's Avatar
Default Re: (G2 Speed)
Yeah get rid of LS tranny, go b16, gsr, or itr. If you look around you'll find out you can just rebuild it with stock internals and still run a fairly good amount of boost, there are several upon several ls motors hitting 300+hp on boost with stock internals...maybe just get some arp's and use the money you save on internals to piece together your turbo kit.
Old Jul 18, 2006 | 03:58 PM
1sick4dr.'s Avatar
any idears on how much a turbo will cost if i peice it together, i can usually come across some deals and find someone to install cheap i no alot of ppl
Old Jul 18, 2006 | 04:02 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandman17 &raquo;</TD></TR><TR><TD CLASS="quote">any idears on how much a turbo will cost if i peice it together, i can usually come across some deals and find someone to install cheap i no alot of ppl</TD></TR></TABLE>
$500.00
homemadeturbo.com
Old Jul 18, 2006 | 04:15 PM
FalkenSiR's Avatar
No matter what people tell you, shorter gears always = shorter acceleration, given that you have good traction.
Old Jul 18, 2006 | 05:27 PM
Syndacate's Avatar
Default Re: (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">The OP is contradicting himself. If you are going all motor, then your best bet is K20, not the lowest powered B series motor, the LS.
LS will be lucky if it makes over 200 whp in na form</TD></TR></TABLE>
Hrm, which is stronger..the LS or the B16a2? I realize the #'s would sya the B16 but I'm pretty sure the LS hasa longer stroke (better compression) as well as more displacement (more torque)
Same stock hatch/coupe/sedan w/ a B16 vs LS would be interesting to see...
With that asside I think you can make an LS 200whp in N/A form..if you can make a D16Z6 do it, you can make an LS do it...
Old Jul 18, 2006 | 05:29 PM
G2 Speed's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Hrm, which is stronger..the LS or the B16a2? I realize the #'s would sya the B16 but I'm pretty sure the LS hasa longer stroke (better compression) as well as more displacement (more torque)
With that asside I think you can make an LS 200whp in N/A form..if you can make a D16Z6 do it, you can make an LS do it...</TD></TR></TABLE>
oh hell yea, ls is a great engine
great torque compared to a b16, but you wouldn't want to make just an LS engine n/a, without the help from your friend vtec
Old Jul 18, 2006 | 08:50 PM
1sick4dr.'s Avatar
you guys are lots of help i no the basics but im a quick learner when i comes to cars, i grew up in the muscle car world and just got out of the jeep world so im trying to learn hondas, im very good with basics, i no the differences b/t motors and trannys and what came out of what, but all these sensors and wiring are weird haha, im catching on as i read you guys' posts, so thanks again and i hope im not being too retarded for you guys
Old Jul 18, 2006 | 08:53 PM
Syndacate's Avatar
Haha<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
great torque compared to a b16, but you wouldn't want to make just an LS engine n/a, without the help from your friend vtec </TD></TR></TABLE>
Haha, definately friend vtec But I was just thinking of the LS in stock form
Milano DC
Jun 14, 2006 04:48 PM
ogabudiah
May 11, 2005 08:47 AM
D-tuned
Oct 7, 2004 11:31 AM
Flexin5
Aug 31, 2004 02:58 AM
B_1_8_hatch
Nov 20, 2003 07:52 PM
