FS: D16Z6 JG 85VT35 cam & AEM cam gear SOHC powa!
I have for sale a JG 85VT35 camshaft that I just pulled from one of my D16Z6 heads. I also have an AEM 3 bolt tru-time adjustable cam gear that can be sold with or without the cam. If you search, you will find that many guys run this cam N/A, supercharged, and turbo with good results. I included a link below to a dyno graph off of JG's website of a 200hp D16Z6 running this cam. Granted he has a few other things done, but if this cam was total garbage, then he wouldn't be seeing these kind of numbers on just 9psi from a JRSC. This cam is also the same cam sold for D16Y8 heads, so if you have a Y8, this cam is for you too.
If you bought this cam from JG, you would have to send in your OEM cam (or pay the core charge of $140), wait for them to regrind and parkerize it, and also pay $280 for them to do it... or you can just buy from me for much cheaper (no core needed
Adobe PDF format dyno graph
Asking:
CAM IS SOLD
$50 for the cam gear ONLY (comes with keyway for install)
here is a link to specs on the cam http://jgenginedynamics.com/Adobe%20pdf%20...GE_CAMSPECS.pdf
Duration is measured @.015 lift
Lift Intake -- 310/410
Lift Exhaust -- 393
Duration Intake -- 230/300
Duration Exhaust -- 274
Valve lash Intake -- .007
Valve lash Exhaust -- .009
EDIT (10/07/09): I have this cam back up for sale. I ended up using it for a while, and now I don't need it anymore.
EDIT (10/09/09): the cam is sold, but the cam gear is still available
PM me if interested or if you have questions.
)Adobe PDF format dyno graph
Asking:
CAM IS SOLD
Lift Exhaust -- 393
Last edited by DelSolDon; Oct 9, 2009 at 02:31 PM. Reason: CAM IS SOLD, CAM GEAR STILL FOR SALE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapump2003 »</TD></TR><TR><TD CLASS="quote">100shipped LMK</TD></TR></TABLE>
sorry, a little too low for both the cam and cam gear
i'll try to get a picture up ASAP
