d16z6 cam on a d16y8
D Tranny Guru
Re: d16z6 cam on a d16y8 (Built to Spill Esquire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built to Spill Esquire »</TD></TR><TR><TD CLASS="quote">adjustable cam?
If you're referring to cam gear all d-series are interchangeable.</TD></TR></TABLE>
more false info..............
The D16Yx cam gears use a different index than 88-95 cam gears.
1/2 tooth off as always.....
You can use it, but will have to set the cam gear to 5 degrees to keep cam in stock timing before adjusting.
madcrossover
11-01-2006 06:52 AM
