Is there anything better than silicone connectors?
i kno a cheap way around this. if u live near any truck stop or cemi shop. ask them for the tube u need and they have radiator hose u could use and they sell it by the footor charge pipe conectors 4 real cheap.
Wiggins Clamps!
http://www.burnsstainless.com/....html
or these from Z10 Engineering http://www.z10eng.com/ VBand Intercooler Interconnects
http://www.burnsstainless.com/....htmlor these from Z10 Engineering http://www.z10eng.com/ VBand Intercooler Interconnects
I like nitrile couplers, made with radiator hosing from NAPA auto parts.
11 bucks a foot, and it pretty much adheres to the piping when it gets heat cycled.
I've boosted before with the hose on with NO clamps and it held for several days!
the only problem is, if u need to ever get it off, you have to stick a screwdriver under it to peel it off the piping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge »</TD></TR><TR><TD CLASS="quote">Wiggins clamps.
That looks like something you'd see in an S&M Sex Shop or something... LoL
</TD></TR></TABLE>That looks like something you'd see in an S&M Sex Shop or something... LoL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">I like nitrile couplers, made with radiator hosing from NAPA auto parts.
the only problem is, if u need to ever get it off, you have to stick a screwdriver under it to peel it off the piping</TD></TR></TABLE>
YES!!! another NAPA lover!!
they are mad leet n cheap :heart:
it doesnt stick as bad as u make it sound for me tho lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party »</TD></TR><TR><TD CLASS="quote">YES!!! another NAPA lover!!
it doesnt stick as bad as u make it sound for me tho lol</TD></TR></TABLE>
well it pisses me off when you try to get it off and scratch up your nicely painted piping
what size would you use for 2.5" piping?
looks like it.. $163 for 2.5"! that must be for spaceshuttle intercooler.
Complete Coupling Assembly, minus O-rings
Size
Part Number
Wt. - lbs
Assembly
1/2
W991-8DE-050-A
.054
$72.12
5/8
W991-10DE-063-A
.062
$75.40
3/4
W991-12DE-075-A
.075
$85.66
W991-16DE-100-A
.096
$96.55
1 1/4
W991-20DE-125-A
.112
$97.60
1 1/2
W991-24DE-150-A
.128
$124.71
1 3/4
W991-28DE-175-A
.146
$131.80
W991-32DE-200-A
.177
$146.20
2 1/2
W991-40DE-250-A
.209
$169.38
Size
Part Number
Wt. - lbs
Assembly
1/2
W991-8DE-050-A
.054
$72.12
5/8
W991-10DE-063-A
.062
$75.40
3/4
W991-12DE-075-A
.075
$85.66
W991-16DE-100-A
.096
$96.55
1 1/4
W991-20DE-125-A
.112
$97.60
1 1/2
W991-24DE-150-A
.128
$124.71
1 3/4
W991-28DE-175-A
.146
$131.80
W991-32DE-200-A
.177
$146.20
2 1/2
W991-40DE-250-A
.209
$169.38
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuarterMileMaster »</TD></TR><TR><TD CLASS="quote">
That looks like something you'd see in an S&M Sex Shop or something... LoL</TD></TR></TABLE>
or my car LOL
I have all 3 inches...from TB, Intercooler inlet, intercooler outlet and the Turbo outlet uses V-band
They're about $ 200 PER UNION for 3" setup...yeah, they do get expensive
stan
or my car LOL
stan
To me, this is the MOST baller thing I have seen on Honda-tech.
If I bought one, I would expect a new jar of KY with it.
They do look sweet though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party »</TD></TR><TR><TD CLASS="quote">******* baller ****</TD></TR></TABLE>
**** I would just run V-Bands for that kinda money , and also Iam not balla enoff , lol
I'm curious if flex pipes hold pressure?
Maybe its because I have my pipes mostly welded and only use couplers in areas that it won't be pulling them apart, or only have run 11psi max...but the 4-ply silicone hose and SS t-bolt clamps I use hold just fine. I don't even have any paint/beads/screw heads/etc to help hold the clamps on, and I ran it in an EF w/o the front motor mount, an OEM rear mount, and filled side mounts. Rocked like a cradle when you gave it throttle, and nothing ever popped off.
Properly made silicone couplers with aramid fiber (kevlar) really shouldn't have issues with high clamping loads or high pressures. I don't doubt a $200 part won't do its job, but that just reminds me of the gold-plated bidets (*** washers) that Saddam had everywhere. Nothing beats a well-designed charge pipe system though.
BTW - I would guess thats a centripetal SC, since you usually only see roots-styles with aftercoolers, and centripetal's with piping for intercoolers.
JDM_ITR
Apr 25, 2002 11:56 AM
