light hesitation at 2-3 rpm cruisin light trottle...
Old Apr 21, 2002 | 04:57 PM
91HATCH's Avatar
Default light hesitation at 2-3 rpm cruisin light trottle...
i have a 91 honda civic dx hatch with a jdm b16a...it has light hesitation at 2-3 rpm cruisin at light throttle....its not throwin no codes....
Old Apr 21, 2002 | 05:36 PM
Urban Business
Guest
Posts: n/a
Default Re: light hesitation at 2-3 rpm cruisin light trottle... (91HATCH)
check spark plugs, rotor, cap, wires. make sure tbody moves freely. could be clutch chattering a lil bit on flywheel
Old Apr 21, 2002 | 06:24 PM
91HATCH's Avatar
bought brand new cap and rotor wires and plugs....tbody moves freely...any other ideas why its hesitatin?
Old Apr 21, 2002 | 06:33 PM
B16ED4G's Avatar
if you are running the two O2 sensor setup, swap your O2 sensor wires around, mine did the same thing, Someone here posted that fix and it worked perfect, no hesitation now
Chris
Old Apr 21, 2002 | 06:59 PM
91HATCH's Avatar
Default Re: light hesitation at 2-3 rpm cruisin light trottle... (B16ED4G)
yeah..did that too still didn't do any difference..i swaped the o2 sensor
Old Apr 21, 2002 | 07:12 PM
Hung's Avatar
Sorry, no reply but I have a question on swapping the two O2 sensor wires around. I'm having the same problem but my O2 sensors have different plugs. One green and one white. And they can't interchange.
Old Apr 21, 2002 | 08:25 PM
91HATCH's Avatar
Default Re: light hesitation at 2-3 rpm cruisin light trottle... (Hung)
my friend put another connector on mines...
Old Apr 21, 2002 | 09:42 PM
CRX7's Avatar
cut, strip, and solder the wires
Old Apr 22, 2002 | 02:24 AM
brad.'s Avatar
Default Re: light hesitation at 2-3 rpm cruisin light trottle... (CRX7)
disconnect the green o2 connector....and it should go away....BUT, your CEL will go on sometimes due to the o2.....but the hesitation will cease
Old Apr 22, 2002 | 05:08 AM
ricodemus's Avatar
mine has what I would describe as a "cough" at 3k (I just got the b16 in too) when I'm crusing in 4th or 5th. My check engine light is on anyway because of the vtec solenoid, but it (the check engine light) flashes once at the cough, then everything is fine. I experienced something similar to this on my d16a6, I was wondering if it could maybe be the fuel filter? My o2 sensors are spliced together because I have the dc headers. Maybe this shoulda been a new topic...but it sounds sort of similar.
Old Apr 22, 2002 | 11:33 AM
Hung's Avatar
Default Re: light hesitation at 2-3 rpm cruisin light trottle... (ricodemus)
I thought the Pr3 ecu required 2 O2 sensors. I'll try it and re-post.
Thanks,
Hung
Old Apr 22, 2002 | 12:00 PM
ricodemus's Avatar
the pr3 and pw0 should require 2, but I'm saying that I'm only using one sensor and its wired so that it gives the readings like its both sensors. that is worded awfully, but you get what I'm saying.
Old Apr 22, 2002 | 02:45 PM
handiman15's Avatar
when you talk about switch the o2 wires. do you switch the wires at the ecu, or at the O2 sensors themselves?
Old Apr 23, 2002 | 06:43 AM
Hung's Avatar
Default Re: light hesitation at 2-3 rpm cruisin light trottle... (handiman15)
yea, I was wondering the same thing. Wouldn't it be easier to switch the wire at the ecu instead of cutting and soldering? Also what difference does the green plug one make that no one is using? If I wire both O2's into the white plug, would my check engine light go off?
LOW_ONBILLETS
Jun 28, 2010 03:27 PM
incurable
Jan 1, 2007 07:31 PM
BlkB16EK9
May 4, 2006 12:19 AM
delta88
Sep 19, 2005 07:37 PM
