dizzys?
Old Jul 18, 2006 | 11:24 AM
v8killa91's Avatar
Default distrubters
can i use my dx dizzy on my mini me? or do i have to use the ex dizzy. my car is a 00 dx and the head is a d16y8? i checked the treads and none weather or not to change it
Modified by v8killa91 at 1:45 PM 7/18/2006
Old Jul 18, 2006 | 12:51 PM
v8killa91's Avatar
Default Re: distrubters (v8killa91)
bump help please?
Old Jul 18, 2006 | 12:59 PM
v8killa91's Avatar
help
Old Jul 18, 2006 | 01:06 PM
Inline6 Silvia's Avatar
if im not mistaken, you must use the EX dizzy. i dont have much experience with D-series motors so please dont quote me on that
Old Jul 18, 2006 | 01:08 PM
Sleepy_Red_hatch's Avatar
Default Re: distrubters (SoSoLow)
you need a vtec sohc dizzy that matches your OBD setup. example : if you are OBD1, you need a D16Z6 dizzy, if you are obd2, you need a D16Y8 dizzy
Old Jul 20, 2006 | 09:31 PM
v8killa91's Avatar
bump
Old Jul 20, 2006 | 09:49 PM
Built Beast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8killa91 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
WTF...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">you need a vtec sohc dizzy that matches your OBD setup. example : if you are OBD1, you need a D16Z6 dizzy, if you are obd2, you need a D16Y8 dizzy</TD></TR></TABLE>
He is exactly right... no need to bump! You must use a OBDI dizzy from a EX or SI (SOHC VTEC) EX were made from 93-95 and Si were made from 92-95.
Old Jul 20, 2006 | 10:12 PM
ddd4114's Avatar
Default Re: distrubters (Built Beast)
actually...you CAN use your DX dizzy...but with some modifications...here's mine:
the internals for all 92-00 dizzys are the same, except for whether they're obd1 or obd2. If the housing will bolt up, it'll work. The only thing you may have to do is convert from obd1 to obd2 or vise versa.
Old Jul 20, 2006 | 10:19 PM
biggdogg's Avatar
Default Re: distrubters (ddd4114)
if you need an obd-1 dizzy i have one from my old z6. pm me .
Old Jul 20, 2006 | 10:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">actually...you CAN use your DX dizzy...but with some modifications...here's mine: </TD></TR></TABLE>
yes that is also an option, but a little too ghetto for me
Old Jul 20, 2006 | 10:28 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built Beast &raquo;</TD></TR><TR><TD CLASS="quote">yes that is also an option, but a little too ghetto for me </TD></TR></TABLE>
Ghetto? Yes...but I like $80...
Old Jul 20, 2006 | 10:35 PM
VRD^don's Avatar
yes u can use your dx dizzy...it has the same bolt pattern as the y8 one does....no need for rewiring either..yes IT WILL WORK!! you can not use the z6 dizzy as in it wont bolt up..
Old Jul 25, 2006 | 07:18 PM
v8killa91's Avatar
Default Re: distrubters (k_motor)
thanx dude your a life saver. saved me about 100 big ones thanx i owe u
DopeEJ1-510
Northern California (Sales)
33
Dec 23, 2007 01:50 AM
Sketch_hs
Feb 25, 2007 11:34 AM
import810
10
Aug 8, 2006 03:48 PM
vg7z
Aug 2, 2005 03:57 PM
alleyezonme
17
May 12, 2005 06:53 PM
